HTTP Layer-7 load-balancing
hermanaccd
Hi, I would like to accomplish the following.
www.xyz.com resolves to a VIP on the Cisco ACE 4700 on HTTP.
When a client types in http://www.xyz.com/bcd, I would like the request to be redirected to www.bcd.com
How do I go about doing this? Do I need to create a real-server with an IP address that resolves to www.bcd.com? How do I configure the Layer-7 match? Do I match on http-url for /bcd?
Are there any examples? Any examples would be appreciated.
Thank you.
Gilles Dufour
you will need a webhost redirect rserver.
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA1_7_/configuration/slb/guide/rsfarms.html#wp999814
You will also need to match your url with a class-map
class-map type http loadbalance match-any MyURL
2 match http url /bcd
Then in your http loadbalancing policy-map, you match the class-map MyURL and assigned the serverfarm with your webhost redirect rserver and then you add a class-default to match the rest of the traffic and assign it a serverfarm with your local rservers.
Gilles.
Thanks for your help!
Hi Gilles,
I followed your advice about using webhost redirect rserver, but the ACE doesn't seem to recognize the match-http-url.
I also can't ping the VIP, even though the VIP is active, and the probes are successful.
I've attached my ACE configuration. Can you take a look and see if I'm missing something or doing something wrong?
Thank you.
