http not forwarded as https by ssl
k.hashisho
Community Member
I have the following problem with my serverfarm:
http flow initiated from a serverfarm is not being handled by the load balanced ssl blades that’s supposed to forward traffic as https to its destination.
To compare the traffic, I am including test flows from 2 serverfarms, one of them is successfully handling the flow translation and the other one is not:
- From real server side, we’re initiating http connections to destination xx.yy.tt.104
- real server 192.168.11.35 (vip xx.yy.zz.124) http connection is translated to https by the SSL blades
- real server 192.168.11.47 (vip xx.yy.zz.73) http traffic is not translating to https and is not leaving the ContentSwitchingModule via vlan200:
Where:
* SRV-005 real address is 192.168.11.47 (vip xx.yy.zz.73) &
* SRV-001 real address is 192.168.11.35 (vip xx.yy.zz.124)
* real server side vlan: vlan301
* internal ssl vlan: ssl vlan201
* destination side transit vlan: vlan200
http flow from real server 192.168.11.35 leaving the ContentSwitchingModule as https:
LN-PRO-CSW001>sh mod csm 3 conn client 192.168.11.35
prot vlan source destination state
In TCP 301 192.168.11.35:1212 xx.yy.zz.12:389 ESTAB
Out TCP 200 xx.yy.zz.12:389 xx.yy.zz.124:22395 ESTAB
In TCP 201 192.168.11.35:1388 xx.yy.tt.104:443 ESTAB
Out TCP 200 xx.yy.tt.104:443 xx.yy.zz.124:22601 ESTAB
In TCP 301 192.168.11.35:1360 xx.yy.zz.12:389 ESTAB
Out TCP 200 xx.yy.zz.12:389 xx.yy.zz.124:22572 ESTAB
In TCP 301 192.168.11.35:1388 xx.yy.tt.104:80 ESTAB
Out TCP 201 xx.yy.tt.104:80 192.168.11.35:1388 ESTAB
http flow from real server 192.168.11.47 not leaving the ContentSwitchingModule as https:
LN-PRO-CSW001>sh mod csm 3 conn client 192.168.11.47
In TCP 301 192.168.11.47:1291 xx.yy.tt.104:80 ESTAB
Out TCP 201 xx.yy.tt.104:80 192.168.11.47:1291 ESTAB
In TCP 301 192.168.11.47:1301 xx.yy.tt.104:80 ESTAB
Out TCP 201 xx.yy.tt.104:80 192.168.11.47:1301 ESTAB
The following config is included on the 6500 content switch module and ssl module:
NL-PRO-CSM001#
static nat xx.yy.zz.73
real 192.168.11.47
static nat xx.yy.zz.124
real 192.168.11.41
real 192.168.11.35
serverfarm SRV-01/77
nat server
no nat client
predictor leastconns
real 192.168.11.35
inservice
real 192.168.11.41
inservice
probe LT-T:3389
serverfarm SRV-005
nat server
no nat client
real 192.168.11.47
inservice
vserver SRV-005-VIP
virtual xx.yy.zz.73 tcp 0
serverfarm SRV-005
persistent rebalance
inservice
vserver SSLtt.104:80
virtual xx.yy.tt.104 tcp www
serverfarm SSL_MODULES
inservice
no nat server
no nat client
real 192.168.10.68
inservice
real 192.168.10.69
inservice
NL-PRO-SSL001#
ssl-proxy service SSL-tt.104:80 client
virtual ipaddr xx.yy.tt.104 protocol tcp port 80 secondary
server ipaddr 192.168.10.67 protocol tcp port 443
certificate rsa general-purpose trustpoint test123
no nat server
trusted-ca ppCA
authenticate verify signature-only
inservice
Gilles Dufour
if you don't have a version higher or equal to 2.1(2) for the SSLM, you are probably hitting bug
CSCed77583
SSL Module invalidate a source IP address using local mask
It looks like it works except for some ip addresses and therefore the bug mentioned above seems like a good match.
Gilles.
Gilles Dufour
CSCed77583
Gilles.
Hi Gilles,
It is exactly what you are suggesting.
The SSL vlan is applying its /28 mask when handling http traffic from the real server ip 192.168.11.47/24. SSL then replies to connection attempts with a RST as it interprets the.47 real server ip as a broadcast address.
Big thanks.
