URL-Based Load Balancing
jrichterkessing
Level 3
Level 3
I'm having a difficult time trying to configure load balancing on my CSM based on the URL entered. Here is my scenerio:
Two web servers (WebA & WebB), load balanced on a CSM. WebA & WebB have 90% the same content, so most traffic can be load balanced between them without a problem. The problem (for me anyway) comes in where WebA has certain web sites that WebB doesn't, and vice versa. So I need to load balance to both for 90% of the traffic, and point traffic to a particular server the other 10% of the time based on the URL entered.
Below is the test config I have so far (that doesn't work correctly), what I am trying for in this example is that any URL that contains /vhosts/ or /programs/ be directed to WebA, and any URL that contains /platform/ or /ssl/ be directed to WebB, and all other traffic be load balanced between the two evenly. (For testing purposes, the servers are being load balanced in "bridge-mode", in production they will be "routed-mode"....I did't want to go through the change controls to change the IP addresses for the test servers!).
module ContentSwitchingModule 2
vlan 605 client
ip address 10.63.240.4 255.255.255.0
gateway 10.63.240.1
vlan 606 server
natpool URL-POLICY-TEST 10.63.240.204 10.63.240.204 netmask 255.255.255.254
map SRV-A url
match protocol http url /vhosts/*
match protocol http url /programs/*
map SRV-B url
match protocol http url /platform/*
match protocol http url /ssl/*
serverfarm URL-POLICY-TEST
nat server
nat client URL-POLICY-TEST
real 10.40.109.100
inservice
real 10.40.109.101
inservice
serverfarm URL-TESTA
nat server
real 10.40.109.100
inservice
serverfarm URL-TESTB
nat server
real 10.40.109.101
inservice
policy TESTWEB-A
url-map SRV-A
policy TESTWEB-B
url-map SRV-B
vserver URL-POLICY_TEST
virtual 10.63.240.10 tcp 0
vlan 605
sticky 1
persistent rebalance
slb-policy TESTWEB-A
slb-policy TESTWEB-B
inservice
Gilles Dufour
what is not working exactly ?
From the config I would say you are missing the command 'persistence rebalance' to break persistency.
Except that, everything looks good.
Gilles.
Thanks for the reply Gilles....I've been out of the office for a while.
Well, right now nothing is working....except that all traffic is going to the default server farm assinged to the vserver. Here are the URLs I am testing with:
**************TEST A************
http://10.63.240.10/manual/vhosts/fd-limits.xml
http://10.63.240.10/manual/programs/apachectl.xml
**************TEST B************
http://10.63.240.10/manual/platform/ebcdic.xml
http://10.63.240.10/manual/ssl/ssl_compat.xml
***************BOTH****************
http://10.63.240.10/manual/howto/htaccess.xml
http://10.63.240.10/manual/howto/cgi.xml
When I try attaching to the first URL for example, here is the connection info (I trimmed it down so it will fit here):
MOSL1S1A#sh mod csm 2 real
real server farm Conns/hits
10.40.109.100 URL-POLICY-TEST 1
10.40.109.101 URL-POLICY-TEST 0
10.40.109.100 URL-TESTA 0
10.40.109.101 URL-TESTB 0
MOSL1S1A#
MOSL1S1A#sh mod csm 2 conn
prot vlan source destination
In TCP 605 10.47.10.10:3738 10.63.240.10:80
Out TCP 605 10.40.109.101:80 10.63.240.204:8820
I've tried changing the syntax on the URL statement in the map as such:
/manual/*
*/manual/*
/manual/
*manual*
/manual*
could you get a 'sho mod csm X vserver name detail' and a 'sho mod csm X memory' as well as the complete config.
I don't see anything wrong in what you're doing currently.
Gilles.
The IN vlan is 605 and the OUT vlan is 605 too. Shouldn't the OUT vlan be 606 (server vlan)? If not, why not?
Is the server in VLAN 606?
Pascal
