HTTP Performance Issue at 560 CE
paltel
Level 5
Level 5
Dear All;
We are using 560 CE for the first time for chacing Internet Traffic "Http only" ; Transperant chacing and IP spoofing are in use; every thing working fine except that there is significant delay or slowness in HTTP response?
Is there and any known cases for this problem.
Note: about 6 M traffic are redirected to the Cache and Cisco says that 650CE support up to 20M throughput.
Thanks In advance.
Mohannad Khuffash
CCNP, MCSE
Gilles Dufour
Do 'sho tech' and check the reason for miss/revalidate/no store.
Try to configure
'http cache .....' to cache a maximum of traffic.
Also, use 'http client-no-cache ignore'
Finally, you might need to capture some sniffer traces with and without the cache to see what is happening exactly.
Gilles.
