https front end and http backend
yycsandman007
Level 2
Level 2
Hi there....I am having a small issue....I have a web app that is https based....I have installed the cert on the CSS, and DNS for this app points to the VIP....the client is wanting to have an https front end, and then load balance in http to the backend servers....the issue I am running into is that this only works if I have an active port 80 rule on that same VIP....if I suspend the port 80 rule and only leave the port 443 rule active on that VIP, it doesn't work....please see appropriate config portions below....Thanks in advance!
Sandeep
ANy suggestions? I have been trying this for a couple of days now...it works fine if the backend sessions are also https, but the client has changed their requirement....
ssl-proxy-list SSL1
ssl-server 1
ssl-server 1 rsakey app1-test
ssl-server 1 rsacert app1-test
ssl-server 1 vip address 10.19.55.10
ssl-server 1 cipher rsa-with-rc4-128-md5 10.19.55.10 81
backend-server 1
backend-server 1 port 81
backend-server 1 server-ip 10.19.55.132
backend-server 1 ip address 10.19.55.132
backend-server 2
backend-server 2 port 81
backend-server 2 server-ip 10.19.55.133
backend-server 2 ip address 10.19.55.133
backend-server 3
backend-server 3 port 83
backend-server 3 server-ip 10.19.55.132
backend-server 3 ip address 10.19.55.132
backend-server 4
backend-server 4 port 83
backend-server 4 server-ip 10.19.55.133
backend-server 4 ip address 10.19.55.133
backend-server 5
backend-server 5 port 85
backend-server 5 server-ip 10.19.55.132
backend-server 5 ip address 10.19.55.132
backend-server 6
backend-server 6 port 85
backend-server 6 server-ip 10.19.55.133
backend-server 6 ip address 10.19.55.133
active
service webserver002:81
port 81
keepalive port 2199
keepalive type tcp
protocol tcp
active
service webserver003:81
port 81
keepalive port 2199
keepalive type tcp
protocol tcp
add ssl-proxy-list SSL1
active
service webserver002:83
port 83
keepalive port 2399
keepalive type tcp
protocol tcp
active
service webserver003:83
port 83
keepalive port 2399
keepalive type tcp
protocol tcp
active
service webserver002:85
port 85
keepalive port 2599
keepalive type tcp
protocol tcp
active
service webserver003:85
port 85
keepalive port 2599
keepalive type tcp
protocol tcp
active
service SSL_Front
slot 2
type ssl-accel
keepalive type none
active
owner app1-test
content app-test_back
add service webserver002:81
add service webserver003:81
add service webserver002:83
add service webserver003:83
add service webserver002:85
add service webserver003:85
balance aca
protocol tcp
port 81
active
content app1-test_front
application ssl
add service SSL_Front
protocol tcp
port 443
advanced-balance ssl
balance aca
active
You can send it to [email protected] or you can upload it here
5 Replies 5
Diego Vargas
Well I find this a little confusing. First of all I see clear traffic on port 81 and not 80, and you have a content rule in port 81, so I guess that is what you mean.
Now, it is expected that this will not work if you suspend the clear text rule since that this is the proper configuration.
You need to have the rule in port 443 to match traffic coming from the client and the clear text rule (port 81) to match traffic already decrypted coming from the SSL module
Thanks for the quick reply....there is another port 80 rule setup for that vip....I was using that to test with the app until I got the front end https rules working....
my port 80 rules just says listen to 10.19.55.10 on port 80 and load balance btwn the webervers on port 8x in the back end...
I am trying to do https front end and http backend....
no where in my SSL config have I configured port 80....but when I suspend that rule it all fails....
I am wondering if the backend server sessions are happening properly?
I don't fully get what you mean by "You need to have the rule in port 443 to match traffic coming from the client and the clear text rule (port 81) to match traffic already decrypted coming from the SSL module"
Haven'tI done that?
Thanks again!
Sandeep
Hi Sandeep,
Can I get the full config to see where is breaking out?
Thanks!!
can you send me your email?
