Https health monitor not working on ACE.
Amjad Hashim
Hello Guys,
Hope you are all doing well, i need some help in setting up my https health monitor for real servers.
I am configuring it on ACE appliance 4710 but the probe appears failing.
The VIP is listening on port 443 and 8080, the cert is not uploaded to ACE but eventually it will be on ACE so SSL will terminate on ACE but not at the minute.
The user don't want to enable port 80 on server so will need https health probe configuring. Following is my config for https health probe but it is failing.
probe https SSDSD-ServerAvailability-443
  interval 5
  passdetect interval 5
  ssl version all
  request method head url //ssdsd/servlet/SDLogin
  expect status 200 200
As per my knowledge https is also an http probe but encrypted. Please see the detailed output below and let me know if i am missing anything.
probe       : SSDSD-ServerAvailability-443
type        : HTTPS
state       : ACTIVE
description :
   port      : 443          address   : 0.0.0.0
   addr type : -            interval  : 5       pass intvl  : 5
   pass count: 3            fail count: 3       recv timeout: 10
   SSL version      : All
   SSL cipher       : RSA_ANY
   http method      : HEAD
   http url         : //ssdsd/servlet/SDLogin
   conn termination : GRACEFUL
   expect offset    : 0         , open timeout     : 1
   regex cache-len  : 0
   expect regex     : -
   send data        : -
                ------------------ probe results ------------------
   associations     ip-address         port porttype probes failed passed health
   serverfarm  : SSDSD_SF
     real      : SSDSD-AL2[0]
                        192.168.225.26  443 VIP     48611  1834   46777  FAILED
   Socket state        : CLOSED
   No. Passed states   : 1         No. Failed states : 2
   No. Probes skipped  : 1         Last status code  : 302
   No. Out of Sockets  : 0         No. Internal error: 0
   Last disconnect err : Received invalid status code
   Last probe time     : Mon Nov 11 04:05:10 2013
   Last fail time      : Mon Nov 11 02:10:00 2013
   Last active time    : Fri Nov  8 09:09:31 2013
                        192.168.225.26 8080 VIP     48613  48613  0      FAILED
   No. Passed states   : 0         No. Failed states : 1
   No. Probes skipped  : 0         Last status code  : 0
   Last disconnect err : Connection reset by server
   Last probe time     : Mon Nov 11 04:05:14 2013
   Last fail time      : Fri Nov  8 08:34:10 2013
   Last active time    : Never
     real      : SSDSD-AL3[0]
                        192.168.225.27  443 VIP     48612  1817   46795  FAILED
   No. Probes skipped  : 0         Last status code  : 302
                        192.168.225.27 8080 VIP     48613  48613  0      FAILED
   Last probe time     : Mon Nov 11 04:05:12 2013
   Last fail time      : Fri Nov  8 08:34:08 2013
PHH104-N3-ACE-1/N3#
I am confused with the last status code which shows 302 any help from your side will be a life line for me.
Amjad Hashim.
5 Replies 5
Kanwaljeet Singh
Hi Amjad,
I see the last disconnect err: "Received invalid status code" which means that ACE is not getting what is  expected (code 200) for it to mark the server as passed.
Also, i see you have configured url "request method head url //ssdsd/servlet/SDLogin", why are you using two slashes "//", can you try with only one?
Also, if you configure probe on TCP PORT 443 does  it pass? I see last disconnect err: connection reset by server as well and that could be due to the fact that service was there on  server. Looks unlikely since above probes failed due to wrong status code which means that SSL handshake happened.
You can take a pcap on server as well as ACE to see what is going on. You might need to use private key to decrypt the captures if the failure is after SSL handshake has completed to see what status code server is sending. You can also use TCP 443 based probe as workaround till you can arrange pcaps and figure out what is wrong.
Kanwal
Hi Kanwaljeet,
Thanks for your quick reply, i have changed the double slash to single but of no vain .
When you said tcp port 443 do you mean http on port 443?? I have tried and it is not receiving any response at all.
One more question 200 response code is it the correct response code for https header??
Amjad Hashim.
Hi Amjad,
By TCP PORT porbe i mean you use TCP based probe not http. So ACE will probe the server on TCP PORT 443 on which SSL service is running on server.
Regarding the response code, it is HTTP response code. HTTPS as you know secure HTTP. You should know if the above configured URL will get the 200 response OK or not.
You can take a pcap on client itself to see what is going on or on ACE itself as well.
Kanwal
Hello Kanwaljeet,
Thanks once again for your quick reply, it was somesort of redirect that user was using to redirect clients to login page. We were trying to monitor the same login page and were getting 302.
We changed the monitoring to a different static page in root and same https monitor probe started working. Thanks for your help, take care.
Amjad Hashim.
Hi Amjad,
Sounds good. I could figure from last status code 302 that there was a redirect but somehow didn't mention it.
But i am glad it is resolved and working.
Kanwal
