I need the HTS and ECCN for an XRV-M7-APLN-100G
jorivera
I'm looking for the HTS and ECCN for an XRV-M7-APLN-100G.
AshSe
@jorivera
Due to the lack of available informatio of HTS and ECCN, may I recommend you:
  1. Consult Cisco Documentation: The most reliable source would be official Cisco documentation for the XRV-M7-APLN-100G. Check their product guides, datasheets, or export compliance information.
  2. Contact Cisco Directly: Reach out to Cisco's customer support or export compliance department. They should be able to provide the correct codes.
  3. Work with a Trade Compliance Specialist: If accuracy is critical (for import/export purposes), consider consulting with a professional trade compliance specialist or customs broker. They have the expertise and resources to classify the product correctly.
Hope This Helps!!!
AshSe
Community Etiquette:
  1. Insert photos/images inline - don't attach.
  1. Always mark helpful and correct answers, it helps others find what they need.
  1. For a prompt reply, kindly tag @name. An email will be automatically sent to the member.
