Intermittent TCP probe failure on ACE module
r.shummoogum
Hi:
Desperately looking for some help here and thanks in advance for reading.
I have been migrating a lot of serverfarms from the CSM to an ACE environment successfully so far and now I am at the last step where I am migrating a serverfarm from a CSM enviroment to an ACE environment to a dedicated context.
The real servers RSERVER1 and RSERVER2 are behind the routers R1 and R2 respectively.
During the migration we move Fa1/0 from both R1 to the VSS as shown by the  dotted lines in the diagram.
We killed server vlan 32 and client vlan 33 on both CSM and SW1, SW2( redundany CSM and ACE not shown on diagram)
Activete vlan 32 and 33 on ACE and SW3 etc...
The show serverfarm detail shows operational and then changed to probe-failed intermittently. Ping towards the Rservers works fine from ACE.
I changed the probe from telnet to icmp and same results ( operatonal then failed probe then operational etc...)
The ARP cache from R1 and R2 point to the ACE.
Note that there is also PBR on R1 and R2 to ensure that traffice flows back to ACE.
the probe disconnect error is
"Server reply timeout"
But how come on CSM it works fine. IS there something that needs to be added on the ACE config?
Here is an edited config and drawing
access-list ACL1 line 10 extended permit ip any any
access-list ACL1 line 15 extended permit icmp any any
probe telnet TN3270
  interval 10
  passdetect interval 30
parameter-map type http REBALANCE
  persistence-rebalance
parameter-map type connection TCP_IDLE_8H
  set timeout inactivity 28800
rserver host TN3270_3RDPARTY-SERVER1
  ip address 10.10.20.11
  inservice
rserver host TN3270_3RDPARTY-SERVER2
  ip address 10.10.24.11
  inservice
serverfarm host TN3270_3RDPARTY
  failaction purge
  predictor leastconns
  probe TN3270
  rserver TN3270_3RDPARTY-SERVER1
    inservice
  rserver TN3270_3RDPARTY-SERVER2
    inservice
class-map type management match-any L4_REMOTE-MGT_CLASS
  2 match protocol telnet any
  3 match protocol ssh any
  4 match protocol icmp any
  5 match protocol http any
  7 match protocol snmp any
  8 match protocol https any
class-map match-all TN3270_3RDPARTY
  2 match virtual-address 10.20.128.111 tcp any
policy-map type management first-match L4_REMOTE-MGT_POLICY
  class L4_REMOTE-MGT_CLASS
    permit
policy-map type loadbalance first-match TN3270_3RDPARTY-POLICY
  class class-default
    serverfarm TN3270_3RDPARTY
policy-map multi-match TN3270-INTERFACE-POLICY
  class TN3270_3RDPARTY
    loadbalance vip inservice
    loadbalance policy TN3270_3RDPARTY-POLICY
    loadbalance vip icmp-reply active
    appl-parameter http advanced-options REBALANCE
    connection advanced-options TCP_IDLE_8H
interface vlan 32
  description TN3270 SERVER VLAN
  ip address 10.30.2.2 255.255.255.0
  alias 10.30.2.1 255.255.255.0
  peer ip address 10.30.2.3 255.255.255.0
  no icmp-guard
  access-group input ACL1
  service-policy input L4_REMOTE-MGT_POLICY
  no shutdown
interface vlan 33
  description TN3270 CLIENT VLAN
  ip address 10.20.128.11 255.255.255.0
  alias 10.20.128.10 255.255.255.0
  peer ip address 10.20.128.12 255.255.255.0
  no icmp-guard
  service-policy input TN3270-INTERFACE-POLICY
  no shutdown
ip route 10.10.20.0 255.255.252.0 10.30.2.12
ip route 10.10.24.0 255.255.252.0 10.30.2.13
ip route 0.0.0.0 0.0.0.0 10.20.128.1
6 Replies 6
mwinnett
Level 3
Level 3
Its possible that the telnet probe operates slightly differently between ace and csm in terms of how it checks the welcome message. However, if that was an issue, then I would expect it never to work on the ace. You are really going to have to span vlan 32 across sw3 or sw4 and see what happens when it fails.
Matthew
I did span sw3 and sw4 and the trace shows timeout on the SYN.
I do not see any reason why the SYN would timeout. As we move things back to CSM everything becomes smooth.
Note: the PBR is pointing towards the alia on the active ACE.
I also see in the trace that both primary address and secondary address of the ace sends probes.
We tried to move them on ACE on 2 different occassions with the result.
Note: That ACE has few other contexts tht works just fine.
We will be verifying the cables to see if they are OK.
thanks
This may be a long shot but do you have these vlans configured in any other contexts of the ACE? If so can you run the command "show np 1 interface iflookup" on both the active and standby in the Admin context.
pay note to the "Hostid: X" value. If both ACE show the same value for X then this is the classic shared vlan problem where both ACE are using the same MAC for the physical interface. Keep in mind that this is only an issue if you have the same vlan in more than one context.
If this is the case you can look at the link below for more details. You would then need to hard set the mac addresses with the commands "shared-vlan-hostid x" peer shared-vlans-hostid y" values between 1-16.
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA2_3_0/configuration/rtg_brdg/guide/vlansif.html#wp1025243
Output from my lab with this command. In this case it is Hostid:0.
MR0317-6500-2-ACE-8/Admin# show np 1 interface iflookup
First burnt-in MAC: 00:30:f2:75:79:fb
Last  burnt-in MAC: 00:30:f2:75:79:ff
No of burnt-in MACs: 7
Hostid: 0
Shared vlan macs currently in use (offset from 0): 0-15
Vlan-vmac indexes currently in use: 0-4
Flags:  Valid shared bridged ftstatus ssl-test normalization icmp-guard switch-m
ode ftvlan remove-eth-pad no-of-lifs MR0317-6500-2-ACE-8/Admin# show np 1 interface iflookup
Hostid: 0
hostid is 8 on primary and 4 on secondary. VLAN 32 and 33 have been shutdown on the ACE though as everything has been moved back to the CSM.
I also noticed  that interface vlan 32 is in the admin context with no ip address an is admin down( this is probably something someone forgot to remove). Another context also has vlan 32 allocated but not defined in the context ( that is no interface vlan 32 and ip address etcc).
Looking at the diagram and based on the traces, then my guess it has to be related to the switching infrastructure. When the probe fails, does the syn get to the rserver ?
Matthew
Matthew:
Since I see the SYN on the span ports of SW3 and SW4 then I assume it will make it to the routers R1 and R2 as those are directly connected cables.
Nothing has changed beyond that. Also as the cables(using different cables) get moved back to SW1 and SW2 everyting works fine with 3 way handshake as per trace.
