IOS SLB transparent web-caches
bleroni
Community Member
Hi all,
I wanted to ask if anybody has implemented SLB with transparent web-caches, and if yes how was it done?
can anyone give me a short overview how to implement this? Because I couldn't find enough information on the Cisco site. We are able to implement SLB for various services, but unable to do the same thing with transparent web-caches.
Any help would be greatly appreciated
thanks
jfoerster
Level 8
Level 8
HI,
you can do this for example with a CSS (compare to http://www.cisco.com/en/US/products/hw/contnetw/ps789/products_configuration_example09186a0080093ff3.shtml). This is an example of how to implement transparent caching with a CSS. Same works if you are using a CSM. Required is using a Content Engine.
Joerg
seilsz
Level 8
Level 8
Bleron,
The following link provides a short blurb and configuration example for using IOS SLB with transparent web caches.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1833/products_feature_guide09186a0080086f2b.html#2728400
~Zach
