Showing results forĀ
Search instead forĀ
Did you mean:Ā
ISR 4321/ISR4331 help
We have two ISR
One ISR4331 will be in central office, and one ISR4321 will be at remote site
Is it right i need to configure my ISR4331 as a WAAS central manager and need to add ISR4321 to Appnav?
I need some design help
I also cant connect to my CM ip address
FAILED to enable management services
my interfaces are:
GigabitEthernet0/0/0 192.168.9.1 YES manual up up
GigabitEthernet0/0/1 10.5.36.100 YES manual up up
GigabitEthernet0/0/2 unassigned YES manual down down
GigabitEthernet0 unassigned YES unset administratively down down
AppNav-Compress1 10.5.36.100 YES unset up up
AppNav-UnCompress1 10.5.36.100 YES unset up up
Loopback0 10.4.48.150 YES manual up up
Tunnel0 10.4.48.150 YES unset up up
VirtualPortGroup31 unassigned YES unset up up
Vlan1 unassigned YES unset administratively down down
My WAAS config initial is:
a) WAAS Image and Profile Size:
bootflash:/ISR-WAAS-5.5.1.12.ova (980541440) bytes
ISR-WAAS-750
b) Router IP/mask:
10.5.36.100
255.255.255.0
WAAS Service IP:
10.5.36.8
c) WAAS Central Manager:
10.4.48.100
d) Router WAN Interfaces:
2 Accepted Solutions
yes that's correct - You'll need either a :
  • WAVE appliance (a Wave-294 will do)
  • a virtual WAAS (vCM) running on some hypervisor
as Central Manager.
Best regards
Finn
Technically yes, but please take a look at this :
https://supportforums.cisco.com/discussion/11089901/waas-without-central-manager
Even though the answer is old, it still is valid.
So in short : it will work, but it's not recommended nor supported.
Best regards
Finn
6 Replies 6
Is it right that ISR 4321 and 4331 can be used as a Waas node only ? and cant be used as Central Manager ?
as Central Manager.
Best regards
Finn
Thanks for answer,
I would like to ask you also if it is possible to create WAAS infrastructure between two ISR 4300 only without WCM ?
Thank you
Best regards
Finn
Thank you,
i would like to ask you one thing,
so for example i initially configured waas node:
harddisk:/ISR-WAAS-5.3.5a.5.ova (941127680) bytes
ISR-WAAS-1300
b) Router IP/mask:
Using ip unnumbered from interface Port-channel1.64
WAAS Service IP:
10.5.36.8
10.4.48.100
GigabitEthernet0/
The question is what is the b) menu, what Router/IP mask does the waas need?
The second question is, after initial config, how can i change initial configuration, for example waas service ip or i want to change WAN interface
Thank you
Thank you,
ISR-WAAS-1300
b) Router IP/mask:
WAAS Service IP:
10.5.36.8
10.4.48.100
GigabitEthernet0/
Thank you
