Issue with show Command on Cisco APIC (ACI)
lahcen-ouhas
When attempting to run various show commands on APIC ACI, no output is generated, and the commands are not working as expected.
Could you please assist me in identifying the cause of this issue?
mouadboustta
Troubleshooting APIC ACI Show Command Issues
When show commands on an APIC in Cisco ACI fail to produce output, it often points to underlying issues that require careful analysis. Here are some potential causes and solutions:
  1. Authentication or Session Timeout: Ensure your session is active and authenticated. Re-login if needed.
  2. Insufficient User Privileges: Verify the account's role; it must have the necessary permissions to execute commands.
  3. Database Sync or Resource Constraints: The APIC database might be experiencing sync issues. Try reloading the APIC if faults persist.
  4. High CPU or System Faults: Check system health (acidiag avread) and address any detected faults.
  5. Fabric Connectivity Problems: Verify fabric health (show fabric nodes) and ensure nodes are reachable.
