Issues with ACE after upgrading software
kalugotla1
In the lab we upgraded our ACE4710 to A4(2.1a) version.After giving the command boot system image to the new version ,reload ACE.
After reload It still had the old image
but the  network in the lab was really slow   ,and all the servers had intermittent slowness issue ,so after unpluging the ACEs from the network ,everything  seemed working perfectly fine.
So not sure what caused this issue ,checked the config through the console ,and it is very basic and simple configuration ,and when I did sh ver ,was able to see the latest version.
Experts please advise me on this.
Andrew Nam
Can you post a following output?
sh ver
sh boot (or bootvar)
sh run | inc boot
regards
Andrew
Below are the outputs
Admin# sh ver
Cisco Application Control Software (ACSW)
TAC support: http://www.cisco.com/tac
Copyright (c) 1985-2011 by Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  loader:    Version 0.95.1
  system:    Version A4(2.1a) [build 3.0(0)A4(2.1a) adbuild_21:41:15-2011/07/21_
/auto/adbure_nightly4/renumber/rel_a4_2_1_throttle/REL_3_0_0_A4_2_1A]
  system image file: (hd0,1)/c4710ace-t1k9-mz.A4_2_1a.bin
  Device Manager version 4.2 (0) 20110629:0926
  installed license: no feature license is installed
Hardware
  cpu info:
    Motherboard:
        number of cpu(s): 2
    Daughtercard:
        number of cpu(s): 16
  memory info:
    total: 6226372 kB, free: 4480380 kB
    shared: 0 kB, buffers: 20396 kB, cached 0 kB
  cf info:
    filesystem: /dev/hdb2
    total: 861668 kB, used: 743116 kB, available: 74780 kB
last boot reason:  Unknown
configuration register:  0x1
s0labsw-ace2 kernel uptime is 1 days 15 hours 14 minute(s) 21 second(s)
/Admin#  sh bootvar
BOOT variable = "image:/c4710ace-t1k9-mz.A4_2_1a.bin;image:/c4710ace-mz.A3_2_5.b
in"
Configuration register is 0x1
/Admin# sh run |inc boot
Generating configuration....
boot system image:c4710ace-t1k9-mz.A4_2_1a.bin
boot system image:c4710ace-mz.A3_2_5.bin
The image you are running on the ACE is not the old image. It's A4_2_1a per sh ver.
I guess the issue you are trying to resolve is slowness via ACE after the upgrade.  If this is a right understanding of the problem, then please provide a following info :
1. Can you verify if this problem happens only after the SW upgrade to A4_2_1a ?
2. When you said the network in the lab was really slow, how did you monitor the slowness?  Can you give us more detaled observation?
3. Can you give us more info about the ACE deployment in your lab along with config?
regards
Andrew
with the old config on ACE ,i was able to ping the device and also had remote access to it.After reloading the new image ,The device was not pingable ,(and also was not able to telnet into it).
We had issues reported from serveral dev server teams ,that they servers are not really slow and also couple other network devices were slow,and had intermittent on off connections  .All these were running in vlan 5.
(Servers,ACE,Network Devices ) connected to a 6509 switch.
After disabling the ports on  6509 switch for ACE,Everything started working fine.
Not sure what triggered this performance issue ,but currenly we disable ACE from the network in the lab and everthing is working as before.
These are the files I see in image dir
Admin# dir image:
196847566  May 19 08:26:18 2010 c4710ace-mz.A3_2_5.bin
205733312  Sep 12 15:56:08 2011 c4710ace-t1k9-mz.A4_2_1a.bin
        8  Sep 12 16:09:25 2011 tmpcrashinfo_reason
      912  Sep 12 16:10:31 2011 httpdservercert.pem
           Usage for image: filesystem
                  760950784 bytes total used
                  121397248 bytes free
                  882348032 bytes total
