Keepalives from CSS to SSLM(cat6500 blade)
c.downie
I'm moving from SCA2's to SSLM's(cat6500 Blade), We are using the config below and it works fine but I require to do keepalives to each of the ssl-proxy services.
I've tried to config it the way it was done on the SCA config by using the same IP but changing the ports for each services but SSL-M didn't like this.
Any suggestions ?
content test
protocol tcp
port 443
redundant-index 3
vip address xx.xx.56.156
balance srcip
add service PRTSSL001-UKGR
add service PRTSSL002-UKGR
active
redundant-index 103
ip address 172.16.18.71
type transparent-cache
active
ssl-proxy service test
virtual ipaddr xx.xx.58.156 protocol tcp port 443 secondary
virtual policy ssl prtpolicy
server ipaddr 172.16.18.68 protocol tcp port 8050
certificate rsa general-purpose trustpoint yyyyyyyyyyyyy
no nat server
trusted-ca PRT-CA
authenticate verify all
inservice
brispin
You can use SSL probes on the CSM by use of the TCL script. It is not a true SSL probe, but it will send a SSL client hello and expect a SSL server hello. Example config probe sslProbe script #script SSL_PROBE [0]
