LD with Citrix application not working.
nizami.j
Community Member
We have a scenerio where it is required to load balance a Citrix Server farm.
I have done the basic configuration as follows:
virtual 10.172.1.73:0:0:tcp is
real 10.172.0.82:0:0:tcp is
real 10.172.0.81:0:0:tcp is
bind 10.172.1.73:0:0:tcp 10.172.0.82:0:0:tcp
bind 10.172.1.73:0:0:tcp 10.172.0.81:0:0:tcp
The problem is that the clients are not able to get the session while going to virtual IP. The commands sh real, sh virtual shows the number of conn as 0. sh service command is also not showing any services.
Do I need to mention the port number for the application while defining virtual ip and real ip adds? If yes then what traffic will this box load balance when no port is defined (as in the ex above)
Also does anyone knows what is the port number of Citrix app. at server side?
Any help on this will be very much appreciated.
javed
[email protected]
ciscomoderator
Administrator
Administrator
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
