load balance based on OS
huangedmc
Level 6
Level 6
Is it possible to load balance incoming requests based on client's operating system on ACE?
For example, we have different web pages specifically for Blackberry or iPhones.
Instead of having multiple URL's & VIP's, we'd like to have a single VIP, but load balance traffic to different serverfarms based on client's OS.
litrenta
Level 8
Level 8
You can loadbalance based on User-Agent header, first you need to quantify what Iphone and blackberry use for user-agent for instance from a regular browser you might see:
User-AgentT=Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 2.0.50727)
from an iphone you will typically see:
User-Agent=Mozilla/5.0 (iPhone; U; CPU like Mac OS X; en)
AppleWebKit/420+ (KHTML, like Gecko) Version/3.0 Mobile/1C25 Safari/419.3
you can go to http://www.user-agents.org to find out what strings are used
That being the case you can make classes on the header to match for loadbalancing decisions:
class-map type http loadbalance match-any mobile
2 match http header User-Agent header-value .*iphone
4 match http header Uswer-Agent header-value .*blackberry
then in LB policy say we want to go to farmA for mobile and farmB for pc's
policy-map type loadbalance first-match L7POLICY
   class mobile
     serverfarm farmA
    class class-default
    serverfarm farmB
see:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/configuration/slb/guide/classlb.html#wp1021388
litrenta
Level 8
Level 8
   class mobile
     serverfarm farmA
    class class-default
    serverfarm farmB
see:
