Load Balance https based on url
John Carrascal
Frequent Visitor
Frequent Visitor
I am trying to configure ACE 4710 to load balance base on the URL, If it matches the specific URL ( /456/ ), the traffic will be sent to server farm 456 else the traffic will be sent to server farm 123.
I attached an image of the topology.
Ace Config:
rserver host SRV01_123
  ip address 192.168.1.101
  inservice
rserver host SRV02_123
  ip address 192.168.1.102
  inservice
rserver host SRV01_456
  ip address 192.168.1.111
  inservice
serverfarm host farm_123
  rserver SRV01_123
    inservice
  rserver SRV02_123
    inservice
serverfarm host farm_456
  rserver SRV01_456
    inservice
class-map match-all VIP_Application
  2 match virtual-address 192.168.1.10 tcp eq https
class-map type http loadbalance match-all L7_server_456
  2 match http url /456/
policy-map type loadbalance http first-match LB_Application
  class L7_server_456
    serverfarm farm_456
  class class-default
    serverfarm farm_123
policy-map multi-match ServerGroup1_PM
  class VIP_Application
    loadbalance vip inservice
    loadbalance policy LB_Application
    loadbalance vip icmp-reply
interface vlan 70
  bridge-group 1
  no shutdown
interface vlan 700
  bridge-group 1
  service-policy input ServerGroup1_PM
  no shutdown
Hi John,
If you want to do the offload in the ACE also called SSL termination, it is a two step process:
1- You need to upload your certificate and key to the ACE using FTP or one of the available methods.
2- Create the the SSL proxy service where you add these two files and finally add this service under the policy-multimatch for the VIP in question.
You also need to decide whether you want to keep your server listening in the encrypted port (that would be a two way encryption process called End-to-End SSL) or you can change the port to 80 and leave all the decyption process to the ACE (this would be transparent to the client, the site will show up as HTTPS all the time).
Here you can take a look at the SSL termination process (using clear text port in the backend servers).
Oficial Configuration Example
http://www.cisco.com/en/US/partner/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA4_1_0/configuration/ssl/guide/terminat.html
Cisco Wiki Example
http://docwiki.cisco.com/wiki/SSL_Termination_on_the_Cisco_Application_Control_Engine_Without_an_Existing_Chained_Certificate_and_Key_in_Routed_Mode_Configuration_Example
__ __
Pablo
pablo.nxh
Level 8
Level 8
Hi John,
Unfortunately this can't be done unless you configure the ACE to offload your SSL connections, https information is readable up to layer 4 to the ACE, layer 5 information such as host headers or URL is hidden and can't be matched using L5 policies without decypting the connection within the load balancer.
__ __
Pablo
Hi Pablo,
  Thank you very much for your response.
Can you please show me an example with this kind of configuration?
Thank you a lot.
Hi John,
Cisco Wiki Example
__ __
Pablo
Hi Pablo,
Thank you very much for your responses.
Yours sincerely,
John.
