Load balance multiple URLs on single VIP
dpastor
I have a fairly typical load balance configuration on a pair of ACE appliances running (A3)2.5 and now I need to load balance multiple URIs to these same servers on port 80 to the one VIP. Can someone direct me to a doc that shows a good example of this, or explain it below?
Dave
serverfarm host application
rserver webserver1 80
probe server-80-PROBE
inservice
rserver webserver2 80
inservice
sticky ip-netmask 255.255.255.255 address source application-80-STICKY
replicate sticky
serverfarm application
class-map match-all application-80-CLASS
2 match virtual-address 1.1.1.1.1 tcp eq www
policy-map type loadbalance first-match application-80-POLICY
class class-default
sticky-serverfarm application-80-STICKY
insert-http X-Forwarded-For header-value "%is"
class application-80-CLASS
loadbalance vip inservice
loadbalance policy application-80-POLICY
loadbalance vip icmp-reply
nat dynamic 22 vlan 424
appl-parameter http advanced-options CASE_PARAM
15 Replies 15
Sean,
That does help, thanks again.  The app is very specific on the /uri, but that is a good tip and I will keep the wildcard in mind should we need it.
Dave
