Load balance on CSM with both Firewalsl and Cache engines
nquangvinh
I'm come from VDC#3 ( Vietnam) , we have 2 CSM , 3 firewall , and 8 CE 7325. We configed dual CSMs load balance for 3 FW, and now we want to use one CSM to load balance for CEs. Can you hint me best topylogy network?
6 Replies 6
Gilles Dufour
I would create the vserver and serverfarm for the CE on the internal CSM.
Simply configure it as if there was not fwlb.
I don't know what else to say.
Gilles.
That's right , i've done.
But I has a problem. I configured vserver and CE serverfarm, but i can't telnet or ssh to CEs for management because i configued CEs on CSM server side.
Can you explain for me a best network topology for our case?
your topology is correct.
The problem is your config.
If you need access to the CE ip addresses, you need to configure a vserver to allow this traffic.
Something like
serverfarm FORWARD
no nat server
no nat client
predictor forward
vserver access2ce
vip x.x.x.0/24 any
serverfarm FORWARD
ins
Replace x.x.x.0/24 with the subnet used by the CE.
Gilles.
Thanks for rating this answer.
I've configured all. It's running ok now. Thanks for all your help.
But We have other problem come from our Custumer.
Our custumer needs to access to website : http://Channel.telerate.com.sg.
After authenticate, this website would download java streaming from port 6080 and 14000. But after I take CEs working, our custumer can not access to use that website.
Can someone help me again?
start by capturing a sniffer trace and see what happens with connections to port 6080 and 14000.
Do you have a vserver to catch and allow this traffic ?
Thanks in advance for rating my answers.
Gilles.
This is my config:
vserver FROMCACHE
virtual 0.0.0.0 0.0.0.0 tcp www
vlan 320
serverfarm FWINT-SEC-SF
persistent rebalance
parse-length 2000
inservice
vserver TRANSPARENT
vlan 3
serverfarm CACHE
parse-length 2000
slb-policy CACHE-POLICY
inservice
Can you talk more clearly: " sniffer trace" ?
