Load Balance TMG with Cisco CSS
Avery Spates
I am working with a Customer that is using Cisco CSS to load balance Microsoft TMG 2010.
From the Microsoft TMG, I can see the https probes hitting the TMG Servers. The TMG 2010 recongnizes that the Cisco is trying to establish a 3-way handshake and is dropping every 3rd connection with the following error: "non-SYN packet was dropped because it was sent by a source that does not hane an established connection with the Forefron TMG computer." Since the Microsoft Forefront TMG 2010 Server is Stateful packet inspection firewall, what is the best load balance method for this service? TCP or even worst ICMP.
Below is a snipet of the configuration:
Thank You
Avery
CSS-A# show service Server1-ssl
Name: Server1-ssl  Index: 70
  Type: Local            State: Alive
  Rule ( x.x.x.x  TCP  443 )
  Session Redundancy: Enabled
  Redundancy Global Index: 206
  Redirect Domain:
  Redirect String:
  Keepalive: (SSL-443   5   3   5 )
  Keepalive Encryption:      Disabled
  Last Clearing of Stats Counters: 03/05/2012 16:33:14
  Mtu:                       1500        State Transitions:            4
  Total Local Connections:   0           Total Backup Connections:     0
  Current Local Connections: 0           Current Backup Connections:   0
  Total Connections:         0           Max Connections:              65534
  Total Reused Conns:        0           Weight Reporting:             None
  Weight:                    1           Load:                         2
CSS-A#
CSS-A# show service Server2-ssl
Name: Server2-ssl  Index: 71
  Redundancy Global Index: 207
  Redirect Domain:
  Redirect String:
  Last Clearing of Stats Counters: 03/05/2012 16:53:49
  Mtu:                       1500        State Transitions:            6
  Weight:                    1           Load:                         2
rodrguti_2
It would good to have a capture from the server itself, the TCP keepalive is really simple, as you explained, it is just a 3-way-handshake on port 443.
The CSS is going to use it's vlan IP to generate this keepalive.
So if the server is dropping the connection, it would be good to se the actual behavior of the keepalive.
ICMP is just a ping, and lets say port 443 is not longer open on the server, at the point that the CSS gets the ICMP reply back from the server, the service is going to remain as alive, but the traffic is not going to work, so ICMP is not a good option.
Thanks!
rodrguti_2
Thanks!
Hi Rodrguti,
  We were able to come up with a resolution. We had to change the Health Monitor to TCP 443 and configure a Close Option "FIN" to close the connection. Once we made that change, the TMG saw the connections as an "Initiate Connection" then "Close Connection".
  I will post the configurations used shortly.
Thank You for the response.
