load-balancing CIFS
jfbesnardeau
Frequent Visitor
Frequent Visitor
Is-it possible to test CIFS connection with probe ?
We need to check that unc link is ok (read or write).
Are there some TLC script usuable ?
jsivulka
Level 10
Level 10
You can use the CIFS to load balance file.by default the CSM will not close open connections when a server fails a probe.
You can however change that behaviour, by configuring the "failaction purge" option: in that case, the CSM will send a RST (there is no way to send a FIN) to the clients, for all open connections to that PROBE_FAILED server.
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v4013/release/notes/ws4013rn.html#wp313743
