Load balancing Problem
Ahmede
Level 5
Level 5
We have 2 web servers connected to Cisco 11506 contenet switch.. Then the content switch is connected to 2 firewalls, and the 2 firewalls are connected to to a router and the router is connected to different ISPs. We are load balance between the 2 ISPs. In order to do that we divided the address into two /28 addresses. We also created 2 virtual addresses on the content switch.. The config looks fine but the conentnt switch balance doesn't work when we have 2 VIPs, however it works fine if we have a single VIP..
IP subnet ISP1 10.10.80.32/28
ip subnet ISP2 10.10.80.48/28
Content switch connection with web server subnet 10.10.80.32/27
here's the config..
ip route 0.0.0.0 0.0.0.0 10.10.80.35 1
!************************** CIRCUIT **************************
circuit VLAN1
ip address 10.10.80.39 255.255.255.224
!*********************** SSL PROXY LIST ***********************
!************************** SERVICE **************************
service ssl-serv1
type ssl-accel
slot 5
keepalive type none
add ssl-proxy-list ssl-list1
active
service svr-sun-new-modawala
ip address 10.10.80.43
string test3
active
service svr1
ip address 10.10.80.41
string test
keepalive type http
service svr2
ip address 10.10.80.42
string test1
keepalive type http
keepalive port 80
active
service svr3
string test3
ip address 10.10.80.46
active
service svr5
ip address 10.10.80.45
keepalive type http
keepalive port 80
active
service svr6
ip address 10.10.80.38
keepalive type http
keepalive port 80
active
!*************************** OWNER ***************************
owner ssl-owner
content ssl-rule-2VIP
add service ssl-serv1
application ssl
vip address 10.10.80.50
protocol tcp
port 443
advanced-balance ssl
content ssl-rule1
application ssl
protocol tcp
vip address 10.10.80.40
port 443
active
content sticky-test
protocol tcp
port 80
url "/*"
advanced-balance arrowpoint-cookie
add service svr1
add service svr2
add service svr3
add service svr5
add service svr6
active
content sticky-test-2VIP
port 80
protocol tcp
url "/*"
add service svr1
add service svr2
add service svr3
add service svr5
add service svr6
content sun-modawala
protocol tcp
port 80
url "/newmudawala/*"
add service svr-sun-new-modawala
active
content sun-modawala-2VIP
protocol tcp
port 80
url "/newmodawala/*"
CSS11506#
Gilles Dufour
could you explain what is not working when you have 2 vips ?
Are both vip not working or just one ?
Do you see hits for your content rule if you do a 'show summary' ?
did you sniff the traffic in front of the CSS to see what is going on ?
I see you have only 1 vlan.
Are the servers using the CSS as default gateway ?
If not, how do you guarantee the server responses come back to the CSS ?
Gilles.
