Load Balancing simple question
estebanmartin
Community Member
i'm using CSS 11501 to load balance some web servers using src IP.
if one src IP is directed to certain web server,
How much time has to pass for this same src IP to be directed to other web server?
Thank you in advance!
seilsz
Level 8
Level 8
By default, entries in the sticky table do not time out. The table works on a first-in, first-out basis. The size of the table depends on the amount of memory in the CSS (SCM 144 MB --> 32k, SCM 288 MB --> 128k).
You can change the default timeout value using the 'sticky-inact-timeout ' command.
~Zach
I tried to change the default timeout value,but the sticky-tag-table is always empty.
any ideas?
Are you saying that the stick-table is always empty?
Can you please post the following:
* Your configuration.
* The output from:
CSS11501# llama
CSS11501(debug)# show sticky-table all
~Zach
