Slow stateful failover for mission critical applications
mcristobal
I have two CSS running vip redundancy,ip interface redundancy and redundant-index on a ASR active-backup model.
They are attached to separate 3750 which share vlan info via a port channel.
When the master fails, we see the VRIR negotiation and mastership of VIPs occurs normally but the script that we run to validate our services fails and the services go to a down state.
Since the gateway for the reals is a redundant VIP that stays alive always based on a DUMMY service, we believe this could be a mac address table update on the 3750.
Traffic back from the reals is still sent to the "old" port where the gateway used to live.
Failover takes several minutes and TCP sessions timeout defeting stateful failover.
Any ideas???
MANUEL
5 Replies 5
seilsz
Level 4
Level 4
Manuel,
Are you using the CSSes in a bridged or routed configuration? Is it possible your delay is being caused by STP convergence?
~Zach
Bridge configuration.
here is part of the config....
bridge priority 1700
udp-ip-fragment enabled
tcp-ip-fragment enabled
bridge aging-time 10
arp timeout 60
arp wait 10
bridge spanning-tree disabled
Are there any switch ports connected to either CSS that are in a STP Blocking state?
~Zach
VLAN1 STP State: Disabled
VLAN1: Root Max Age: 6 Root Hello Time: 1 Root Fwd Delay: 4
Designated Root: 06-a4-00-11-93-90-61-78
Bridge ID: 06-a4-00-11-93-90-61-78
Root Port Desg
Port State Designated Bridge Designated Root Cost Cost Port
VLAN11 STP State: Disabled
VLAN11: Root Max Age: 6 Root Hello Time: 1 Root Fwd Delay: 4
Designated Root: 06-a4-00-11-93-90-61-79
Bridge ID: 06-a4-00-11-93-90-61-79
Root Port Desg
e1 Fwd 06-a4-00-11-93-90-61-79 06-a4-00-11-93-90-61-79 0 19 8001
VLAN211 STP State: Disabled
VLAN211: Root Max Age: 6 Root Hello Time: 1 Root Fwd Delay: 4
Designated Root: 06-a4-00-11-93-90-61-7a
Bridge ID: 06-a4-00-11-93-90-61-7a
Root Port Desg
VLAN222 STP State: Disabled
VLAN222: Root Max Age: 6 Root Hello Time: 1 Root Fwd Delay: 4
Designated Root: 06-a4-00-11-93-90-61-7b
Bridge ID: 06-a4-00-11-93-90-61-7b
Root Port Desg
e3 Fwd 06-a4-00-11-93-90-61-7b 06-a4-00-11-93-90-61-7b 0 19 8003
I was referring to the switch ports on the 3750's.
~Zach
