Load balancing SMPP in ACE module
shibi.ravindran
Frequent Visitor
Frequent Visitor
We have a new requirement to load balance 2 servers with SMPP protocol  on ACE module.  The Code which is is running is A21(6a). Can any one suggest whether this protocol is supported for load balancing.
jlamousn
Level 3
Level 3
Hello Shibi,
This protocol can be load balanced by the ace at the TCP layer 4 level. There is no support for the underlying protocol however, so the ace cannot do any layer 7 load balancing decisions for this this protocol.
Joel Lamousnery
Customer Support Engineer
Data Center - Application Networking Services
Joel Lamousnery CCIE R&S - 36768 Engineer, Customer Support Technical Services
