LoadBlancer not working fine
Mohamed.Samhoud1
Community Member
     Hi All,
i   have ACE module in 6.000 series of switches and i configured one   context C1 and i have many serverfarm on of them include 4 probe wit   different ports three of them working fine and forward requests to the   servers proberly, but there is probe of them have a problem as the   requests going to on of the servers only and also it be too delayed.
kindly i need help of you as it is more urgent for me,
as the below is my configuration :
## sh probe TCP2310
probe       : TCP2310
type        : TCP
state       : ACTIVE
   port      : 2310    address     : 0.0.0.0         addr type  : -
   interval  : 5       pass intvl  : 10              pass count : 2
   fail count: 3       recv timeout: 10
                       --------------------- probe results --------------------
   probe association   probed-address  probes     failed     passed     health
   serverfarm  : tabsintlh
     real      : tabsas01[0]
                       10.160.162.24   13170      454        12716      SUCCESS
     real      : tabsas02[0]
                       10.160.162.25   13281      386        12895      SUCCESS
## sh probe detail
probe       : TCP2310
type        : TCP
state       : ACTIVE
description :
   conn termination : FORCED
   expect offset    : 0         , open timeout     : 10
   expect regex     : -
   send data        : -
     real      : tabsas01[0]
                       10.160.162.24   13177      454        12723      SUCCESS
   Socket state        : CLOSED
   No. Passed states   : 37         No. Failed states : 37
   No. Probes skipped  : 72         Last status code  : 0
   No. Out of Sockets  : 0         No. Internal error: 0
   Last disconnect err :  -
   Last probe time     : Fri Dec 23 10:50:16 2011
   Last fail time      : Fri Dec 23 09:03:30 2011
   Last active time    : Fri Dec 23 09:04:45 2011
     real      : tabsas02[0]
                       10.160.162.25   13288      386        12902      SUCCESS
   No. Passed states   : 32         No. Failed states : 32
   No. Probes skipped  : 0         Last status code  : 0
   Last fail time      : Fri Dec 23 08:36:25 2011
   Last active time    : Fri Dec 23 08:37:40 2011
## sh run | b serverfarm host tabsintlh
  failaction purge
  probe TCP2100  >>>>>is working fine
  probe TCP2310  >>>>>is not working and we are using to by path the loadbalancer in that port
  probe TCP3210 >>>>>is working fine
  probe TCP7779 >>>>>is working fine
  fail-on-all
  rserver tabsas01
    inservice
  rserver tabsas02
    inservice
sticky http-cookie 10.10.96.110 GROUP1
  cookie insert browser-expire
  timeout 720
  timeout activeconns
  replicate sticky
Mohamed.Samhoud1
Community Member
any update plz as it is critical issue,
problem can be on server side. I think, server has problem open connection on port 2310/tcp (maybe tcp timeout, or delay connected to resource limit, or dns, or something like this).
Regards on delay on server side, change 'interval' from 5sec to for example 15sec. Let me know, if it's helpful.
martin
