09-02-2016 06:22 AM
Concerning a Cisco 2960 switch. I logged on to change the IP address which it accepted. When I logged into the new IP address to save, it would not accept the same userid and passwords that I entered to change the IP address. What gives?
09-02-2016 07:48 AM
you logged in and changed the mgmt. ip address of the switch , did you save it then or log back and try and save , changing ip address should have no effect on the actual username and password credentials its just for reachability that address on layer 2 switch
Are you using ACS and AAA security
09-06-2016 11:01 AM
I think here there are diferent cases:
But i need more information about your problem.
Please put your
sh run | begin line vty
