Management Interface security
wilson_1234_2
Level 7
Level 7
What is the recommended setup for the managment interface physical location?
If the CSS is sitting between the firewall and Internet router, is it best not to use this interface?
dkirsch
Level 3
Level 3
If you meant that your CSS is not protected by the Firewall, then you are right to want to lock it down as much as possible. Using the physical management interface on a SEPARATE (out of band) LAN connection which in turn is only accessable from firewalled connection inside of DMZ would be appropriate.
