Max number of CSR on ACE
kashman37
Dear all,
I have 8 CSR requests on one Context on ace for a Public CA. When i try to create the ninth CSR i get the following error "Error: maximum number of CSR params already defined" does that mean i cannot create any new CSRs on the Specific Context? If i delete the Old CSRs will it impact the certificates that were generated though the specific CSR? is it safe to delete CSRs that were used to generate Certificates on ACE and if yes why does ACE keeps the CSRs in its configuration?.
Thanking you in advance.
nygenxny123
It is pefectly safe to delete the CSR and still keep the validity of the cert you created it with.
I'm not sure why there is a limit on 8.
I delete CSR's all the time.
It's can look a little confusing when it shows up in the config..but it is safe to delete
nygenxny123
Thanks a lot Dude.
