Max Parse Length on CSM
andrew.burns
Level 11
Level 11
We've had to increase the parse-length multiplier to fix some application issues, but does anyone know if it introduces any scalability issues or anything like that?
And, as a second question, if we see in the output of the "show csm stats" command that we have hits on the "Reached max parse len" counter, how do we find out which vserver they relate to?
thanks,
Andrew.
There will definitely be some impact.The setup/teardown rate for HTTP requests is inversely propotional to the header size.
I think You would need to sniff the wire to see who is sending packets with headers
larger than you have configured to support.
Syed
