MAX SSL connections possible on ACE Module?
waltermavely
What are MAX SSL connections possible on ACE Module? Is it based on Context or total number of connections on ACE?
inayathulla1
Hi Walter,
Please find the explanation below:-
a)
Maximum number of SSL connections 100 K
b)
Maximum number of SSL transactions persecond (TPS):-
By default, the ACE supports 1000 SSL TPS.Installing an optional SSL TPS license allows you to increase the number of TPS your ACE supports.
Shariff
