07-27-2009 08:44 PM
I still have some old 3660 routers running 123-15 IOS in my network, I am wondering whether these routers level of WCCP will work with 4.1.3a, presently I am running 4.1.1c. the majority of the routers are 2851s running 124-15.T8 so should not be a problem upgrading to 4.1.3a..so would there be any problems if I left the WAEs at the 3660 sites running 4.1.1c and upgrqade the others to 4.1.3a?
08-06-2009 06:17 AM
Richard,
WCCP interoperability should not be affected by upgrading to 4.1.3.
Zach
08-06-2009 01:06 PM
We have a mix of 4.1.1c, 4.1.3, 4.1.3a, and 4.1.3b, and all are functioning without a problem. I agree with Zach, if you are running WCCP on these devices today, you should not have a problem when you upgrade them to the new code.
