Module ACE: Monitoring via GUI. It´s can?
Hi all,
I´ve a question. Does the ACE Module has a GUI for monitoring purposes, as does the ACE Appliance?
Jaime.
Gilles Dufour
The same GUI exists for the ACE module.
It's called ANM.
However, it does not come onboard of the ace module.
You need to order it separately and install it on a Linux server.
http://www.cisco.com/en/US/partner/products/ps6904/index.html
Gilles.
Thanks Gilles,
I´m going to review the software. This allows me obtain statistics of equal form that Device Manager?
Jaime.
This is exactly the same software.
The appliance just have it running onboard...
Gilles.
