Module SSL SM WS-SVC-SSL-1-K9
lomonaco
Hi Everbody,
I have three doubts about the module SSLSM in a Switch 65009
1) Is necessary some license file or procedure to activate
the module SSL SM, PN SM WS-SVC-SSL-1-K9 ?
2) The module comes from the Cisco with the version 3.1.1.
I take a look in the software download area
(http://www.cisco.com/cgi-bin/tablebuild.pl/cat6000-ssl)
and see that the version 2.1(10) is the more recent ?
Should I make the downgrade and if yes where can I find
some documentation about that ?
3) I did all the configuration by CLI. It works fine, but
the CiscoView Device Manager for SSLSM 1.1(271)
don?t recognize my commands.
I can do something to solve this problem ?
Thanks in Advanced
Andre Lomonaco
brispin
Q1)Is necessary some license file or procedure to activate the module SSL SM
No need license to active the SSL SM module.
Q2) refer this link :http://www.cisco.com/en/US/products/hw/switches/ps708/prod_release_note09186a00805eceab.html#wp201055
