Monitoring statistics displayed incorrectly after upgrade to A4(1.1)
richardacarey
After upgrading from A3(2.0) to A4(1.1) I noticed that all of the Real Server connection statistics on the monitoring tab are incorrect. For example, on one real server I am seeing a display of 55,834,574,861 for current connections which is obviously incorrect. These numbers do change after refreshing the page so it is getting these stats from somewhere. Other than that the upgrade went perfectly fine.
Has anyone else experienced this? Is there a way to clear these statistics without pulling the real servers out of the farm?
Any insight would be greatly appreciated. Thanks.
Nicolas Fournier
Hi Richard,
It looks to be a bug on the new software which reports wrong value through SNMP and through the DM.
We don't have a clear workaround for now but you can still check the values through the CLI as I believe these should be accurate.
Nicolas
Hi Richard,
FYI, a new bug has been opened for this issue: CSCtq51405 ACE 4710 SNMP POLLING Shows huge connections.
Nicolas
