MSISDN Based sticky problem
tevfik
We need persistency (or sticky load balancing) based on MSISDN and destination ip&port pairs.
My content configuration shown below:
owner WEBLOGIC
content weblogic
add service msisdn-9001-1
add service msisdn-9001-2
add service msisdn-9001-3
add service msisdn-9002-1
add service msisdn-9002-2
add service msisdn-9002-3
url "/*"
advanced-balance wap-msisdn
protocol tcp
port 9003
vip address 10.200.148.15
active
As a service ,there are 3 server (ofcourse 3 IP) But each server has 2 instance (Port 9001 and 9002)
Here is the service configuration:
ip address 10.200.148.20
protocol tcp
port 9001
keepalive type tcp
keepalive port 9001
active
ip address 10.200.148.21
protocol tcp
port 9001
keepalive type tcp
keepalive port 9001
active
ip address 10.200.148.60
protocol tcp
port 9001
keepalive type tcp
keepalive port 9001
active
protocol tcp
port 9002
keepalive type tcp
keepalive port 9002
active
protocol tcp
port 9002
keepalive type tcp
keepalive port 9002
active
protocol tcp
port 9002
keepalive type tcp
keepalive port 9002
active
But I didn't achieve that coming MSISDN go to always same service.
a-vazquez
Level 11
Level 11
Please confirm that you want to configure stickiness both based on the MSISDN header and the destination ip/port. What you can try to do in this case is set a separate content rules based on the destination port and use the 'advanced-balance wap-msisdn' in conjunction with the content rule based on the destination port.
