Named Keepalive problem
tevfik
hi,
I have two named keepalive config. and both of them exactly the same except port number. Such as:
keepalive SPDA_Transcoding_80
port 80
ip address 10.X.Y.49
uri "/KeepAlive.bin"
type http
active
and
keepalive SPDA_Transcoding_81
port 81
type http
active
Keepalive for port 80 is running but 81 is not.
When I check the show keepalive output:
Name: SPDA_Transcoding_80 Index: 1 State: Alive
Description:
Address: 10.X.Y.49 Port: 80
Type: HTTP:HEAD:/KeepAlive.bin
Encryption: Disabled
Frequency: 5
Max Failures: 3
Retry Frequency: 5
Dependent Services:
SPDA_AnTrTS01_port80
and
Name: SPDA_Transcoding_81 Index: 2 State: Down
Description:
Address: 10.X.Y.49 Port: 81
Keepalive Error: Not reachable failure
Frequency: 5
Max Failures: 3
Retry Frequency: 5
Dependent Services:
SPDA_AnTrTS01_port81
As yyou see that there is an error in port 81 keepalive that "Not reachable failure"
But when I go to browser and write down the http://10.X.Y.48:81/Keepalive.bin, I get correct answer.
Do you have any idea about caused this problem.
Gilles Dufour
take a sniff on the server and verify if the server sends a response to the CSS when coming on port 81.
If you see a response tell us what css software version you have.
Gilles.
YES!
I sniffed the traffic.
Altough port 80 sends HTTP 200 OK code, port 81 does not.
So Problem is about coding of application.
Thank you..
