NAT issue? Help?
jcotter
Community Member
Okay, I've got a small issue that I think is a NAT problem. Could someone look over this config and tell if I've done something amazingly stupid? I can get to the load balanced addresses of 10.0.4.67:7080 and 10.0.5.98:8080 but NOT 10.0.4.68:8080 (notice that the hosts and the vip are on the same subnet). That's why I'm thinking that NAT is the problem. VLAN 255 is 10.0.0.0/16 and VLAN 72 is 10.99.72.0/24. Also, I can get to the host directly at 10.0.4.73 at port 8080 with no problems directly. It just won't come through the CSS.
!*************************** GLOBAL ***************************
no restrict web-mgmt
snmp name "CSS1a"
logging host 10.0.55.2 facility 0 log-level debug-7
ip route 0.0.0.0 0.0.0.0 10.0.0.2 1
!************************* INTERFACE *************************
interface 1/1
trunk
vlan 72
interface 1/2
trunk
vlan 255
!************************** CIRCUIT **************************
circuit VLAN72
ip address 10.99.72.100 255.255.255.0
ip virtual-router 72 priority 200 preempt
ip redundant-interface 72 10.99.72.10
circuit VLAN255
ip address 10.0.5.109 255.255.0.0
ip virtual-router 10 priority 200 preempt
ip redundant-interface 10 10.0.5.134
ip redundant-vip 10 10.0.5.98
ip redundant-vip 10 10.0.4.67
ip redundant-vip 10 10.0.4.68
!************************** SERVICE **************************
service shsnjp2.xxxx.com
ip address 10.99.72.45
keepalive type http
keepalive port 8080
active
service shsnjp3.xxxx.com
ip address 10.99.72.140
keepalive port 8080
keepalive type http
active
service sqasn01.xxxx.com
ip address 10.99.72.50
keepalive port 7080
keepalive type tcp
keepalive method get
active
service sqasn02.xxxx.com
ip address 10.99.72.51
keepalive port 7080
keepalive type http
service sqesn01.xxxx.com
ip address 10.0.4.90
keepalive port 8080
keepalive type http
service stbsn01.xxxx.com
ip address 10.0.4.73
keepalive port 8080
keepalive type http
active
service stbsn01b.xxxx.com
keepalive port 20000
keepalive type http
active
!*************************** OWNER ***************************
owner xxxx
content Endeca
add service sqesn01.xxxx.com
add service stbsn01.xxxx.com
balance weightedrr
vip address 10.0.4.68
port 8080
protocol tcp
active
content Endeca-2
balance weightedrr
protocol tcp
port 20000
active
content JBoss
add service shsnjp2.xxxx.com
add service shsnjp3.xxxx.com
protocol tcp
vip address 10.0.5.98
port 8080
advanced-balance sticky-srcip
redundancy-l4-stateless
active
content QA
add service sqasn01.xxxx.com
add service sqasn02.xxxx.com
protocol tcp
port 7080
balance weightedrr
vip address 10.0.4.67
active
!*************************** GROUP ***************************
group servernat
active
jcotter
Community Member
I solved my problem. I left out where I was applying the NAT in the group servernat. I applied the NAT to the stbsn01.xxxx.com server (under the group servernat) and that fixed the problem.
For anyone who has a similar problem the syntax is:
group servernat
add destination service stbsn01.xxxx.com
active
