NAT on a css using VIP/Interface redundancy
dbjelf
Community Member
I have two css-11151's set up using VIP and
interface redundancy in an active/backup
configuration. We are using source groups
to NAT all outgoing connections to a single
ip. Config looks like this:
Primary css:
group nat-clients
vip address 192.168.1.10
active
clause 50 permit any 192.168.100.0 255.255.255.0 destination any sourcegroup nat-clients
Secondary css:
group nat-clients
active
My question is, is there a way to make
the source groups redundant? I am not
allowed to unless there is a content
rule associated with the ip used in the
source group. Doing a "sh group" on each
css shows that both groups are active/not
redundant. On occasion I will see duplicate
ip address messages in the logs but NAT works regardless.
-Dan
Gilles Dufour
Dan,
I believe you can.
Just configure an 'ip redudant-vip XX 192.168.1.10' under the appropriate circuit.
Let me know if that does not work.
Gilles.
Hi Gilles, when I do 'ip redudant-vip XX 192.168.1.10' I get this:
%% Could not find content rule for specified VIP address.
-Dan
Hi Dan,
What version of WebNS are you running? This looks like bug id CSCdz49395. I was able to ge this working on 7.10 b305:
CSS11506# sh run
!Generated on 01/07/2005 08:27:39
!Active version: sg0710305
configure
!************************** CIRCUIT **************************
circuit VLAN1
ip address 1.1.1.2 255.255.255.0
ip virtual-router 1
ip redundant-vip 1 1.1.1.1
!*************************** GROUP ***************************
group TEST
vip address 1.1.1.1
CSS11506#
~Zach
dbjelf
Community Member
Ooh thanks Zach. That looks like my problem.
-Dan
