Need advice renewing Thwarte Certificate on CSS11503
d-fillmore
Level 2
Level 2
I'm after some guideance as to how to renew a Thwarte server certificate on a pair of CSS11503 devices.
My customer has received the certificate from Thwarte and it's in .pxf format. He said that when they last renewed they didn't need to generate a a CSR, so looking at Thwarte's web site I'm assuming this means that the CSR is re-signable within their system.
The documentation on CCO states that I then need to copy the file onto the CSS.
My first query is, will I be able to copy a .pxf file onto the CSS as from the syntax it look like the device is expecting a PEM file.
The next query I have is, how do I know what is inside a .pxf file? Do I need to contact Thwarte or is the .pxf format always just a certificate?
This question refers to this paragraph in the docs;
"After you import or generate certificate and key pair files, you must indicate to the CSS whether these files contain certificates, private keys, or Diffie-Hellman parameters. You do this by associating certificate names, private/public key pair names, or Diffie-Hellman parameter names with the particular imported files"
If anyone can give me any pointers on this I'd appreciate it
Many Thanks, Dom
Dom
If you want to roll back, I recommend you copy and associate the new cert with other name as below.
copy ssl ftp DEFAULT_FTP import LoadBalancer_new.pfx PKCS12 "password" "password"
(config)# ssl associate cert *.mysite.co.uk_new LoadBalancer_new.pfx
(config)# ssl associate rsakey *.mysite.co.uk_new LoadBalancer_new.pfx
If you face the problem, you can roll back the cert by changing ssl-proxy-list only.
The following is a step to import, apply new cert and rollback config.
## initial config
!*************************** GLOBAL ***************************
  ssl associate rsakey oldkey old.p12
  ssl associate cert oldcert old.p12
!*********************** SSL PROXY LIST ***********************
ssl-proxy-list test
  ssl-server 1
  ssl-server 1 vip address 192.168.77.100
  ssl-server 1 cipher rsa-export-with-rc4-40-md5 192.168.77.100 80
  ssl-server 1 rsakey oldkey
  ssl-server 1 rsacert oldcert
  active
## import the new cert
CSS11503# copy ssl ftp DEFAULT_FTP import new.p12 PKCS12 "cisco" "cisco"
CSS11503# conf t
CSS11503(config)# ssl associate rsakey newkey new.p12
CSS11503(config)# ssl associate cert newcert new.p12
CSS11503(config)# ssl-proxy-list test
CSS11503(config-ssl-proxy-list[test])# ssl-server 1 rsakey newkey
CSS11503(config-ssl-proxy-list[test])# ssl-server 1 rsacert newcert
CSS11503(config-ssl-proxy-list[test])# sus  <<== Even when suspended the ssl-proxy-list, connections are not disconnected and CSS  keeps using old cert. When 'active' command was issued, existing connections are disconnected and new key and cert are loaded on CSS.
CSS11503(config-ssl-proxy-list[test])# act
## new config
  ftp-record DEFAULT_FTP 1.160.0.52 root des-password ig5haaufqbnfuarb /tftpboot/webns
ssl-proxy-list test
  ssl-server 1
  active
If CSS works fine after activating ssl-proxy-list, you can remove old cert.
If CSS doesn't work, you can roll back with the following config.
CSS11503# conf t
CSS11503(config-ssl-proxy-list[test])# no ssl-server 1 rsakey
CSS11503(config-ssl-proxy-list[test])# no ssl-server 1 rsacert
CSS11503(config-ssl-proxy-list[test])# ssl-server 1 rsakey oldkey
CSS11503(config-ssl-proxy-list[test])# ssl-server 1 rsacert oldcert
Yuji
yushimaz
I'm not sure about .pxf format. Does it mean Personal Information Exchange(PFX) file?
If so, you can import this file as pkcs12 format.
.pfx - PFX, predecessor of PKCS#12 (usually contains data in PKCS#12 format, e.g, with PFX files generated in IIS)
http://en.wikipedia.org/wiki/X.509#Certificate_filename_extensions
To copy this file into CSS, please issue 'copy ssl' command as below.
CSS11503# copy ssl ftp DEFAULT_FTP import pkcs.p12 PKCS12 "cisco" "cisco"
DEFAULT_FTP : ftp record
pkcs.p12 : cert file
first cisco : The password used to DES encode the file
second cisco : The pass-phrase used to protect the contents of the file
For more detail regarding 'copy ssl' command, please refer to the following URL.
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v7.30/configuration/security/guide/SSL.html#wp1451811
After importing, you can see the file as below.
CSS11503(config)# show ssl files
File Name                       File Type File Size
rsakey                          PEM        887
rsacert                         PEM        1050
pkcs.p12                          PKCS12     2389 <<==
And also you can associate the key and cert with 'ssl associate' command as below.
CSS11503(config)# ssl associate cert mycert pkcs.p12
CSS11503(config)# ssl associate rsakey mykey pkcs.p12
CSS11503# sh run global
To verity cert file with your pc, you will need to install openssl and issue 'openssl pkcs12' command as below.
You can confirm the cert and key.
# openssl pkcs12 -in pkcs.p12
Enter Import Password:
MAC verified OK
Bag Attributes
    localKeyID: 63 D4 36 FB 69 E1 DC 76 AD 38 0B 18 87 E7 63 28 46 35 73 BE
subject=/C=JP/ST=Tokyo/L=Shinjuku/O=CiscoSystems/OU=Japan-TAC/CN=yushimaz/emailAddress=yushimaz@cisco.com
issuer=/C=JP/ST=Tokyo/L=Shinjuku/O=cisco/OU=TAC/CN=yushimaz/emailAddress=yushimaz@cisco.com
-----BEGIN CERTIFICATE-----   <<== cert
MIIDEjCCAnsCCQDr6c7BldcySTANBgkqhkiG9w0BAQUFADCBhDELMAkGA1UEBhMC
[snip]
-----END CERTIFICATE-----
Bag Attributes
Key Attributes:
Enter PEM pass phrase:
Verifying - Enter PEM pass phrase:
-----BEGIN RSA PRIVATE KEY-----  <<== private key
Proc-Type: 4,ENCRYPTED
DEK-Info: DES-EDE3-CBC,426191720D232453
JV5+HCfNgJtXg01lJ2pe1baQHaTK8kOFEHNIw9jbmZpiPsTIHfbmHScQuII6yciR
[snip]
-----END RSA PRIVATE KEY-----
Yuji
Thanks for your reply Yuji
You're right I made a mistake with the file extension;
CSS-02# show ssl files
LoadBalancer.pfx                PKCS12     3169
I also have the following in the config
  ssl associate cert *.mysite.co.uk LoadBalancer.pfx
  ssl associate rsakey *.mysite.co.uk LoadBalancer.pfx
So once I've FTP'd the new cert onto the CSS, how do I apply it?
And is it possible I can keep the old one there to roll back if I run into any problems once the new one is applied?
Many Thanks, Dom
Dom
## initial config
ssl-proxy-list test
  ssl-server 1
  active
CSS11503# conf t
## new config
ssl-proxy-list test
  ssl-server 1
  active
CSS11503# conf t
Yuji
Hi Yuji,
I did this change last night and it went like a dream
Thank you so much for your help - much appreciated!
The only thing I had to do differently was that I had to suspend the proxy list before making the changes
Cheers, Dom
