Need help - ACE Redirection/Rewrite
daviddiazp
Community Member
Hi guys, I've seen the examples in previous posts and some others online including the cisco documentation.
I find my scenario a bit different though and have not been able to implement a redirect that works for me.
In DNS i have domainx.com pointing to my server's VIP (A record), and www.domainx.com pointing to a CDN (CNAME record) which returns traffic to my VIP. (because of DNS RFC 1033 I cannot point domainx.com to my CDN which would be ideal).
Either way, I'm trying to make the ACE do a redirect based on the host header in the HTTP request. If the host in the request is the naked domain, then redirect to CDN, if not, just continue to the VIP.
I tried doing:
action-list type modify http cdn_rewrite
header rewrite request Host header-value domainx.com replace www.domainx.com
policy-map type loadbalance first-match LBP_X
  class class-default
    serverfarm SF_X
    action cdn_rewrite
but it doesn't do anything, I see no changes on the client side; i still see domainx.com in the URL and on the headers through Firebug.
I'm afraid a webserver-host redirect will create a loop (as the redirect target -the CDN- will bounce traffic back to me)
What's the best way and/or solution to go around this scenario?
Thanks!
Hi David,
This should do the trick:
rserver redirect CNAME
  webhost-redirection http://www.web.com/%p
  inservice
serverfarm redirect CNAME
  rserver CNAME
    inservice
class-map type http loadbalance match-any Naked
  2 match http header Host header-value web.com
class-map type http loadbalance match-any WWW
  2 match http header Host header-value www.web.com
policy-map type loadbalance first-match LBP_WEB
  class Naked
    serverfarm CNAME
  class WWW
    serverfarm SF_WEB
__ __
Pablo
pablo.nxh
Level 8
Level 8
Hi David,
What you're trying to do here can be achieved using HTTP redirects (301/302); redirection loops should not be a
problem as the ACE works in first-match fashion so if the matches are properly placed within the policy; this shouldn't be an issue.
Can you attach a sanitized copy of your configuration so I can reply with a sample of what needs to be done.
Tnx
__ __
Pablo
Hi Pablo, thanks for the reply.
Here's the relevant config i have in place at the moment
parameter-map type http PER_REBALANCE
  persistence-rebalance
action-list type modify http CDN_web_rewrite
  header insert both Host header-value "www.web.com"
  header rewrite both Host header-value "web.com" replace "www.web.com"
rserver host WEBSERVER1
  ip address 10.49.51.3
  inservice
rserver host WEBSERVER2
  ip address 10.49.51.5
  inservice
rserver host WEBSERVER3
  ip address 10.49.51.7
  inservice
rserver host WEBSERVER4
  ip address 10.49.51.9
  inservice
rserver host WEBSERVER5
  ip address 10.49.51.11
rserver host WEBSERVER6
  ip address 10.49.51.35
rserver host WEBSERVER7
  ip address 10.49.51.37
serverfarm host SF_WEB
  predictor leastconns
  probe ICMP
  rserver WEBSERVER1
    inservice
  rserver WEBSERVER2
    inservice
  rserver WEBSERVER3
    inservice
  rserver WEBSERVER4
    inservice
  rserver WEBSERVER5
class-map match-all VIP_WEB
  2 match virtual-address 1.1.1.1 tcp eq www
  class class-default
    serverfarm SF_WEB
    action CDN_web_rewrite
policy-map multi-match VIPS
  class VIP_WEB
    loadbalance vip inservice
    loadbalance policy LBP_WEB
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 100
Hi David,
  inservice
  rserver CNAME
    inservice
  class Naked
    serverfarm CNAME
  class WWW
    serverfarm SF_WEB
__ __
Pablo
You sir are a life saver. It works perfectly, traffic gets re-routed to my CDN.
Thanks!
