Need Help for redirect to HTTPS
hamz-zackops
Community Member
Hello forum members,
i have difficulty while configuring http to https while accessing specific url.
the case:
i have www.foo-bar.com.god in http, in the web page there is www.foo-bar.com.god/trust/* that must be accessing in https
is there any spesific line of config to apply in my config,
my config is below.
### start
access-list INBOUND line 8 extended permit ip any any
parameter-map type http PERSISTENCE-REBALANCE
persistence-rebalance
parameter-map type ssl SSL_END_to_END
  cipher RSA_WITH_RC4_128_SHA priority 10
  cipher RSA_WITH_3DES_EDE_CBC_SHA priority 7
  cipher RSA_WITH_AES_128_CBC_SHA priority 9
  cipher RSA_WITH_AES_256_CBC_SHA priority 8
  session-cache timeout 600
rserver host PORTAL-A
ip address 10.49.30.200
inservice
action-list type modify http FORCE-HTTPS
ssl url rewrite location "www\.foo\-\bar\.com\.god\trust\*"
header insert  response Cache-Control header-value "private, no-cache, no-store, must-revalidate"
header rewrite response Server header-value "" replace "BLANK"
serverfarm host PORTAL-SFARM
rserver PORTAL-A 80
   inservice
ssl-proxy service PORTAL-CERT
key portal.key
cert portal.crt
sticky ip-netmask 255.255.255.255 address source SOURCEIP-STICKY-HTTP-SFARM
replicate sticky
serverfarm PORTAL-SFARM
class-map match-all SSL-VIP
2 match virtual-address 10.49.30.230 tcp eq https
class-map match-all HTTP-VIP
2 match virtual-address 10.49.30.230 tcp eq www
class-map type management match-any remote_access
202 match protocol icmp any
204 match protocol ssh any
207 match protocol snmp any
208 match protocol telnet any
209 match protocol http any
210 match protocol https any
211 match protocol xml-https any
policy-map type management first-match management
class remote_access
   permit
policy-map type loadbalance first-match LB-PORTAL-L7-POLICY
class class-default
   sticky-serverfarm SOURCEIP-STICKY-HTTP-SFARM
   action FORCE-HTTPS
policy-map multi-match LB-PORTAL-L4-POLICY
class SSL-VIP
   loadbalance vip inservice
   loadbalance policy LB-PORTAL-L7-POLICY
   loadbalance vip icmp-reply
   nat dynamic 1 vlan 260
   appl-parameter http advanced-options PERSISTENCE-REBALANCE
   ssl-proxy server PORTAL-CERT
interface vlan 260
description "User-Access"
ip address 10.49.30.231 255.255.255.192
peer ip address 10.49.30.232 255.255.255.192
access-group input INBOUND
nat-pool 1 10.49.30.252 10.49.30.252 netmask 255.255.255.255
service-policy input management
service-policy input LB-PORTAL-L4-POLICY
no shutdown
### End
need for review the config
thanks and regards
hamzah
5 Replies 5
Kanwaljeet Singh
Hi Hamzah,
The location regex that you enter must be a pure URL (for example, www\.cisco\.com) with no port or path designations if you are using SSL URL rewrite.  If you need to match a path, use the HTTP header rewrite feature to rewrite the string.
action-list type modify http X
header rewrite response Location header-value "http://xxxx\.com/path" replace https://xxxx\.com/path"
Try and let me know how it goes. For simple URL without path your above configuration should work fine.
Kanwal
Hi Singh,
thank you for reply,
i just change the config so hope fully the web can redirecting properly.
but when i apply the config, the Browser say, the connection was reset.
Need help
here is my full config
crypto chaingroup portal-verySign
  cert portal.pem
access-list everyone line 8 extended permit ip any any
  inservice
rserver redirect PORTAL_REDIR_HTTPS
  webhost-redirection https://%h%p 302
  inservice
serverfarm redirect PORTAL_HTTPS_SFARM
  rserver PORTAL_REDIR_HTTPS
    inservice
serverfarm host WWW_PORTAL_SFARM
  rserver PORTAL-A 80
    inservice
sticky http-cookie PORTAL-STICKY STICKY-PORTAL-1
  serverfarm WWW_PORTAL_SFARM
  replicate sticky
action-list type modify http HTTP_MODIFICATION
  header insert request X-Forwarded-Proto header-value "%pd"
  header insert request Via header-value "1.1 web:%pd"
  header insert response Via header-value "1.1 web:ps"
  ssl url rewrite location ".*"
  ssl header-insert session Id
ssl-proxy service CLIENT_PORTAL
  ssl advanced-options SSL_END_to_END
ssl-proxy service SERVER_PORTAL
  key portal-key.pem
  cert portal.pem
class-map type http loadbalance match-any PORTAL-SSL
  2 match http url .*
class-map match-all VIP-SSL-PORTAL
class-map match-all VIP-WWW-PORTAL
policy-map type loadbalance first-match PORTAL_HTTPS_DEFAULT
  class class-default
    compress default-method gzip
    action HTTP_MODIFICATION
    ssl-proxy client CLIENT_PORTAL
policy-map type loadbalance first-match PORTAL_HTTP_DEFAULT
  class class-default
    serverfarm PORTAL_HTTPS_SFARM
policy-map multi-match L4_PORTAL_LB
  class VIP-WWW-PORTAL
    loadbalance policy PORTAL_HTTP_DEFAULT
    loadbalance vip icmp-reply active
  class VIP-SSL-PORTAL
    loadbalance policy PORTAL_HTTPS_DEFAULT
    ssl-proxy server SERVER_PORTAL
interface vlan 260
  description User-Access
  access-group input everyone
  service-policy input L4_PORTAL_LB
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.49.30.195
ip route 10.0.0.0 255.255.255.0 10.49.30.193
need your advice
Hi Hamzah,
Your redirect configuration looks good. It should work. So any user who comes and class match conditon should be redirected to HTTPS and you dont' need NAT there.
Kanwal
hi kanwal,
you mean i should remove "nat dynamic 1 vlan 260" from class VIP-SSL-PORTAL ?
Hi Hamzah,
No i was talking for redirection so you don't need NAT here since traffic is never given to any realserver but ACE itself redirects  it. It shouldn't make any difference but worth a try if it is not working.
Also, i just noticed that you are using end to end SSL which means front and back end connections would be SSL, so why you have defined rserver with port 80 in serverfarm?
rserver PORTAL-A 80-------------------->80 is for http,  you should be using the port on which the server listens. If server listens on port 80 then it means that you cannot use end to end and hence you should remove SSL-PROXY CLIENT configuration from policy map.
inservice
nat dynamic 1 vlan 260----------->Remove this.
Kanwal
