connection from behind one VIP to another
lni1
hello experts,
we have the following setup:
2 different contexts with the same VLAN's on the outside and on the inside.
context1
outside VLAN89 - VIP1 (in VLAN89) - rservers1-2 in VLAN36 (inside)
contect2
outside VLAN89 - VIP2 (inVLAN89) - rservers3-4 in VLAN36. (inside)
now, there is a need to reach an application on VIP2 from servers behind VIP1.
we do source natting on those servers and we can connect from rservers1-2 to ip's in VLAN89.
however, if we try to connect to VIP2: the connection fails. Is this some kind of security mechanism? and if so, is there a way to bypass it?
thanx in advance
Kanwaljeet Singh
hi,
Inter-context traffic is not permitted but there is a work around,
If a rserver S in vlan 10 of context A wants to communicate with vlan 20, VIP-B, you should configure context A with a static host route, pointing VIP-B to the default gateway. This default gateway will then forward the traffic to context B and for ACE it is like the connection comes from outside and not another context. Same for response. You need on context B a route for vlan 10 via the gateway
Please try and let me know.
Kanwal
hi,
thank you for the quick response, but the solution don't work.
i have done the following:
contextA with public side in vlan89 end serverside in vlan 36:
*natting to hide requests from the rserver behind a public address in vlan89 (x.x.246.80)
*a static route to vipB via the DG (route x.x.246.53 255.255.255.255 x.x.246.254)
contextB with public side in vlan89 and serverside in vlan36
*a static route to vipA via DG (route x.x.246.80 255.255.255.255 x.x.246.254)
remark:
*both VIP's are in the same subnet, so no routing is done on the DG)
*when accessing another mazhine in the same subnet (but nog behind ACE° we see correctly the address x.x.246.80, so the outgoing NAT works...
any idea's?
If you ping from rservers or trace route to the context B vip and vice-versa, is it going according to the routing you have configured? If yes,  then it should work fine.
Kanwal
