NEED HELP WITH ACE LOAD BALANCING POLICY PLEASE
raul saurez
I need create a policy that allows incoming connections between two servers I have configured for PLM. From what I noticed there is a jsession ID sticky predictor. Where do I configure the VIP? The policy process is confusing and I dont know where to begin. Here are my two server configs. can anyone help??
rserver host JAG-PLM9APP-02
  ip address 172.28.9.81
  inservice
rserver host JAG-PLM9WEB-02
  ip address 172.28.9.87
  inservice
serverfarm host PLM9-WEB-SF
  rserver JAG-PLM9APP-02
    inservice
  rserver JAG-PLM9WEB-02
    inservice
30 Replies 30
The VIP is now out of service as well as serverfarm. How do I bring backup?
If the servers in serverfarm are down, then VIP will show out of service. You should check why servers are down. I see you have probes configured, so you should do the following:
show serverfarm <serverfarm name> detail
and if servers show probe failed, you should do show probe <probe name>detail and see why it is failing. Also, try to change the probe from HTTP to ICMP and see if it passes. Once the servers are "Operational" VIP will come inservice again.
Kanwal
Note: Please mark answers if they are helpful.
ICMP displays load balancing fully functional and pinging the VIP no problem but cant access http://172.28.18.81/tc/webclient  .. what am I missing that I cant access through http?
Are you able to access the servers directly with http://realip/tc/webclientxxx? ICMP traffic doesn't get loadbalanced to the servers. ACE replies to the packets as long as serverfarm is operational. If you have configured "loadbalance icmp-reply" without ACTIVE statement, then even with SF down, ACE will reply to ICMP requests.
Now, if the same URL works directly on the server, then we need to further TS the problem. When you send the request, take a pcap on client and also take output of "show conn address <address  of the client>" and see if the ACE is forwarding the traffic to server or not. A quick capture on server should also be helpful or even on ACE itself to see what exactly is going on. Also, please paste the relevant configuration that you have currently right now and i will have a look again.
Kanwal
This is what the Probe details are showing. I will switch to ICMP now
bri-200n-ace1/PLM9-TEST# sho probe PLM9-HTTP-PROBE-7010 detail
 probe       : PLM9-HTTP-PROBE-7010
 type        : HTTP
 state       : ACTIVE
 description :
   port      : 7010    address     : 0.0.0.0         addr type  : -
   interval  : 10      pass intvl  : 15              pass count : 2
   fail count: 2       recv timeout: 10
   http method      : GET
   http url         : /HealthMonitor/probe.jsp
   conn termination : GRACEFUL
   expect offset    : 0         , open timeout     : 1
   regex cache-len  : 0
   expect regex     : -
   send data        : -
                ------------------ probe results ------------------
   associations ip-address      port  porttype probes   failed   passed   health
   real        : JAG-PLM9APP-02[0]
     serverfarm: PLM9-WEB-SF
                172.28.9.81     7010  PROBE    4729     4729     0        FAILED
   Socket state        : CLOSED
   No. Passed states   : 0         No. Failed states : 1
   No. Probes skipped  : 0         Last status code  : 0
   No. Out of Sockets  : 0         No. Internal error: 0
   Last disconnect err : Server open timeout  (no SYN ACK)
   Last probe time     : Fri Dec 12 10:15:35 2014
   Last fail time      : Thu Dec 11 14:34:00 2014
   Last active time    : Never
bri-200n-ace1/PLM9-TEST# sho probe PLM9-HTTP-PROBE-7011 detail
 probe       : PLM9-HTTP-PROBE-7011
 type        : HTTP
 state       : ACTIVE
 description :
   port      : 7011    address     : 0.0.0.0         addr type  : -
   http method      : GET
   regex cache-len  : 0
   expect regex     : -
   send data        : -
   real        : JAG-PLM9WEB-02[0]
                172.28.9.87     7011  PROBE    4732     4732     0        FAILED
   Last probe time     : Fri Dec 12 10:16:35 2014
   Last fail time      : Thu Dec 11 14:34:15 2014
Here is the sho conn from my PC with porbes and withought probes.
bri-200n-ace1/PLM9-TEST# sho conn address 172.28.18.81 netmask 255.255.255.0
conn-id    np dir proto vlan source                destination           state
846433     1  in  TCP   18   172.28.18.124:52020   172.28.9.81:8802      SYNSEEN
585042     1  out TCP   18   172.28.9.81:8802      172.28.18.124:52020   INIT
803035     1  in  TCP   18   172.28.18.124:53454   172.28.9.87:8801      SYNSEEN
1055157    1  out TCP   18   172.28.9.87:8801      172.28.18.124:53454   INIT
1129526    1  in  TCP   18   172.28.18.124:18954   172.28.9.87:8803      SYNSEEN
1724705    1  out TCP   18   172.28.9.87:8803      172.28.18.124:18954   INIT
bri-200n-ace1/PLM9-TEST# sho conn address 172.28.1.64 netmask 255.255.255.0
1392620    1  in  TCP   18   172.28.1.64:55045     172.28.18.81:8801     SYNSEEN
1270689    1  out TCP   18   172.28.9.81:8801      172.28.1.64:55045     INIT
This output clearly indicates that ACE has seen the SYN and has forwarded the SYN to server but haven't got the SYNACK back. I would strongly recommend to check if the server replies to the URL directly or not.
You can have more details about the similar outputs here:
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_%28ACE%29_Troubleshooting_Guide_--_Troubleshooting_Connectivity
Kanwal
But both servers are running. I can ping them both.
172.28.9.81 & 172.28.9.87.
Where do you believe the issues lie? on the two real servers?
Are you able to telnet to the servers on the port on which they are listening through VIP? No doubt, you are able to ping the servers from ACE but you are sending a HTTP request. I don't see it going to HTTP even, the tcp three way handshake itself is not completing which indicates that either the server is not listening on that port or server is replying to SYN with SYN-ACK but it never reaches ACE due to asymmetric routing in your network. You should take a pcap on server to see what is going on. At this point, yes i would doubt servers.
Kanwal
Iit looks like I can telnet into the servers on the specified ports then a black screen shows and it kicks me backout to the PC CLI
Hello Kanwal,
I wanted to see if I can run something by you real quick.  As we confirmed the loadbalancing is working, however, the client said that I am supposed to implement a config that will allow access to server via web browser. this is what we get when attempting....
Server Error
404 - File or directory not found.
The resource you are looking for might have been removed, had its name changed, or is temporarily unavailable.
He gets the login through here http://jag-plm9web-02:8801/tc/webclient
But not when he tries to go through the VIP here  http://172.28.18.81/tc/webclient
He informed me that last time a policy had to be put in place to allow this link to work http://172.28.18.81/tc/webclient  … I thought that I did but I am still receiving the same server error. Can you check my config and see what is missing so that the load balancer can be put in production? I have bolded the changes that I made. Thank you!
bri-200n-ace1/PLM9-TEST(config)# do sho run
Generating configuration....
access-list ANYONE line 10 extended permit ip any any
probe icmp PING-PROBE
  interval 10
  faildetect 2
  passdetect interval 30
  passdetect count 2
  receive 4
probe http PLM9-HTTP-PROBE-8801
  port 8801
  interval 10
  faildetect 2
  passdetect interval 15
  passdetect count 2
  request method get url /HealthMonitor/probe.jsp
  expect status 200 200
  open 1
probe http PLM9-HTTP-PROBE-8802
  port 8802
  interval 10
  faildetect 2
  passdetect count 2
  open 1
probe http PLM9-HTTP-PROBE-8803
  port 8803
  interval 10
  faildetect 2
  passdetect count 2
  open 1
probe http PLM9-HTTP-PROBE-8804
  port 8804
  interval 10
  faildetect 2
  passdetect count 2
  open 1
parameter-map type http HTTP-MAP1
  persistence-rebalance
  inservice
  inservice
  predictor leastconns
    probe PLM9-HTTP-PROBE-8802
    probe PLM9-HTTP-PROBE-8804
    inservice
    probe PLM9-HTTP-PROBE-8801
    probe PLM9-HTTP-PROBE-8803
    inservice
class-map type http loadbalance match-any L7-PLM9-Enterprise
  2 match http url /tc/webclient.*
class-map type management match-any PM_MULTI_MATCH
  201 match protocol snmp any
  202 match protocol xml-https any
  203 match protocol telnet any
  204 match protocol ssh any
  205 match protocol icmp any
  206 match protocol https any
  207 match protocol http any
class-map match-all VS_Classmap
  2 match virtual-address 172.28.18.81 tcp any
policy-map type management first-match management
  class PM_MULTI_MATCH
    permit
policy-map type loadbalance first-match PLM9-WEB-LB-POLICY
  class L7-PLM9-Enterprise
    serverfarm PLM9-WEB-SF
policy-map multi-match PM_MULTI_MATCH
  class VS_Classmap
    loadbalance vip inservice
    loadbalance policy PLM9-WEB-LB-POLICY
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 109
    appl-parameter http advanced-options HTTP-MAP1
interface vlan 18
  description Client Vlan
  ip address 172.28.18.124 255.255.255.128
  access-group input ANYONE
  service-policy input PM_MULTI_MATCH
  no shutdown
interface vlan 109
  description Servers Vlan
  ip address 172.28.9.7 255.255.255.128
  nat-pool 1 172.28.9.8 172.28.9.8 netmask 255.255.255.0 pat
  no shutdown
ip route 0.0.0.0 0.0.0.0 172.28.18.1
snmp-server contact "ANM"
snmp-server location "ANM"
snmp-server trap-source vlan 18
I see you have not specified ports for servers. Can you define the ports on which servers are listening?
  rserver JAG-PLM9APP-02---------->8802 or whatever
    inservice
  rserver JAG-PLM9WEB-02-------->8801 or whatever port that service is running.
    inservice
Kanwal
I didnt see this message before I sent you one but yes that was the problem!! Thank you!
Nevermind I figured it out, thank you so much for all of your help!!
