need help with http to http url redirect configuration on ACE.
gadle.ravi
hi all,
I have a url say http://abc.pqr.com and I wish to send 301 url redirect message to all my clients to come on http://abc.pqr.com/123.
how can i achieve it using webhost-redirection under redirect r server. or do i need to define an action list for this. I have tried using action list command, but somehow it doesn't work. and how different will webhost-redirection cmd here be in comparison to action-list rewrite command.
Also, would be very kind if any one can help me with url proper meaning of url reg-ex like %s, %p , %h as i am not sure about them.
Thanks..
pablo.nxh
Level 3
Level 3
Hello Ravi,
Action-list is for more specific scenarios when you need to modify something within the HTTP header this is more processing intensive so that's why achieving a 301/302 redirection throught the webhost-relocation method is the way you need to go.
Here is a snippet of how your config should look like to get this working:
rserver redirect SVR
  webhost-redirection http://%h/123
serverfarm host Web
  rserver SRV1
    inservice
  rserver SRV2
    inservice
serverfarm redirect Redirect
  rserver Redirect-SVR
    inservice
class-map type http loadbalance match-any 123
  2 match http url /123.*
policy-map type loadbalance first-match SLB
  class 123
    serverfarm SVR
  class class-default
    serverfarm Redirect
If you have any question let us know.
__ __
Pablo
hi Pablo,
thanks for your reply, looking at this config guess I am almost there as the config that i tried working with is almost the same.
but here I have a query and it would be very kind of you if you can answer that for me.
the layer 7 class map you have configured here is
and you are trying to jst match /123 with help of wild card mask .* i.e. only the /123 be matched in whole URL. instead why can't I match abc.pqr.com/123.*
what difference will it make in mentioning whole URL instead of jst the part of it.
and why should i not be having %p as well in webhost-redirection under redirect r server.
The difference is that if you want to match for example the domain abc.pqr.com  and the uri /123 you will need a class-map like this:
class-map type http loadbalance match-ll 123
  3 match http header Host header-value abc[.]pqr[.]com
Cesar R
--------------------- Cesar R ANS Team
hello Cesar and Pablo
as per your recomendations, I tweked my configuration further, this is how it looks know
rserver redirect 123-Redirect
   webhost-redirection http://%h/123 301
   inservice
class-map type http loadbalance match-all EmuwebX-Redirect-URLmatch-CMap
over here the things look to be working but !  however it seems to be redirecting everything there, clicking through the content seems to always redirect it to the /123 folder.
can you please help me with this.
Thanks..:)
