Need help with initial ACE 4710 config
dclee
Hoping someone can point me in right direction to config guide etc..
Essentially I have 2 Exchange servers on vlan 10.
I want to use the 4710 to sit in front of them and load balance between the 2 servers.
The 4710 and the 2 servers are on the same vlan.
I have configured a VIP, the 2 real servers and the the server farm. Everything appears to be inservice.
Cheers
Dave
Pablo
Hi Dave,
If you have a one-armed design then you require Source NAT to get things working
policy-map type loadbalance http first-match Exchange-PM
  class class-default
    serverfarm Exchange
policy-map multi-match LB
  class Exchange-VIP
    loadbalance vip inservice
    loadbalance policy Exchange-PM
    loadbalance vip icmp-reply active
   nat dynamic 1 vlan 10
interface vlan 10
  ip address 10.10.10.2 255.255.255.0
  access-group input Any
nat-pool 1 10.10.10.10 10.10.10.10 netmask 255.255.255.0 pat
  service-policy input MGMT
  service-policy input LB
  no shutdown
You can use the VIP address or any other available IP address no NAT the request.
__ __
Pablo
7 Replies 7
Pablo
Hi Dave,
  class class-default
    serverfarm Exchange
  class Exchange-VIP
interface vlan 10
  no shutdown
__ __
Pablo
Thanks for the reply and I understand the need for source nating...but was hoping someone could provide me a sample
walk thru of a 1 armed scenario ?
Cheers
Dave
Pablo
Morning Dave,
Gotcha, you're looking for something like this
http://docwiki.cisco.com/wiki/Basic_Load_Balancing_Using_One_Arm_Mode_with_Source_NAT_on_the_Cisco_Application_Control_Engine_Configuration_Example
I've attached a configuration chapter that walks you through the one-arm mode configuration and all its requirements.
__ __
Pablo
Thanks Pablo
I noticed its for the ACE module, does this config also work for the stand alone 4710 appliance ?
From a best practice perspective, is it best to put the ACE VIP on a seperate routed VLAN ?
I notice the network diagram has the ACE on VLAN 50 and the servers on VLAN 51 with the MSFC routing between the 2.
Or can I have both the ACE physical and VIP on the same subnet as my server farm ?
Cheers
Dave
Pablo
Dave,
Yup the configuration lines on the module and the appliance are indentical, I think more of the docs are module oriented because of the sell numbers
Not really the design that you want to implement depends on what's already setup on your environment, regardless of the mode that you want to go with Bridged/One-Armed/Routed you can expect same load balancing performance, for example clients would not go with One-Armed mode if they need to avoid client NAT for auditing purposes or something.
I notice the network diagram has the ACE on VLAN 50 and the servers on VLAN 51 with the MSFC routing between the 2./Or can I have both the ACE physical and VIP on the same subnet as my server farm ?
That's a Cisco's different (weird) sketch for a one-armed design, the diagram that commonly you see is like this
http://img526.imageshack.us/i/onearmed.jpg/
Absolutely you can have ACE/VIP/Servers on the same VLAN as long as source NAT is in place LB should work flawlessly =)
__ __
Pablo
Thanks Pablo, your help is much appreciated
So far I have gotten the load balancer working with 2 servers
in a server farm.
Cheers
Dave
Pablo
Sweeeet! Great to hear the info was useful to get things on the right track
Have a nice one!
__ __
Pablo
