Need help with the below config
skkghello1
Can you please have a look at the below config :
service test-1-6273   --à I understand this part
  ip address 10.10.14.17
  protocol tcp
  port 6273
  redundant-index 33
  keepalive frequency 2
  keepalive maxfailure 2
  keepalive retryperiod 2
  keepalive port 6273
  keepalive type tcp
  active
service test-2-6273 --à I understand this part
  ip address 10.10.30.18
  protocol tcp
  port 6273
  redundant-index 36
  keepalive port 6273
  keepalive type tcp
  active
content test1-content-6273 --à I understand this part
    vip address 10.10.10.232
    port 6273
    protocol tcp
    redundant-index 53
    balance weightedrr
    advanced-balance sticky-srcip
    flow-timeout-multiplier 451
    add service test-1-6273weight 10
    add service test-2-6273weight 1
    active
content test2-content-6273 –Why 2 vips ? (R they for load balacing)
    vip address 10.10.10.233
    port 6273
    protocol tcp
    redundant-index 60
    balance weightedrr
    add service test-2-6273weight 10
    active
group nat-group-test
  vip address 10.10.10.205 ----------> what is this rule for (To nat client ip to css ip --snat)
  redundant-index 54
  add destination service test-1-6273
  add destination service test-2-6273
  active
circuit VLAN20
  description " Upstream "
  ip address 10.10.173.209 255.255.254.0
  ip redundant-vip 10 10.10.10.205
  ip redundant-vip 10 10.10.10.232
  ip redundant-vip 10 10.10.10.233
content map-edge-443
    vip address 10.10.10.205 --------> why are they using the same ip as of group
    port 443
    protocol tcp
   redundant-index 41
    flow-timeout-multiplier 25
    add service star-1-9443
    add service map-edge-002-beta-9443
    active
service star-1-9443
  ip address 10.10.45.17
  protocol tcp
  port 9443
  redundant-index 21
  keepalive type tcp
  keepalive port 8080 --why diff port number , shouldn’t be 9443
  active
service star-2-9443
  ip address 10.10.41.17
  protocol tcp
  port 9443
  redundant-index 1
  keepalive frequency 4
  keepalive port 8004 ----why diff port number , shouldn’t be 9443
  keepalive type tcp
  active
group snat-star –what does this group do
  vip address 10.10.40.100
  add destination service star-1-9443
  add destination service star-2-9443
  redundant-index 56
  active
circuit VLAN645
  ip address 10.10.33.2 255.255.240.0
    ip virtual-router 11 priority 200 preempt
    ip virtual-router 21
    ip redundant-interface 11 10.10.33.1
    ip redundant-interface 21 10.10.33.4
    ip redundant-vip 11 10.10.40.100 ----why
    ip critical-service 11 upstream-downstream-ping
    ip critical-service 21 upstream-downstream-ping
Is the above config correct. thanks
skkghello1
Any help will be appticated.
Marko Leopold
    port 6273
    protocol tcp
    redundant-index 60
    balance weightedrr
    active
Why? Because you use the same tcp port. How shall the CSS know which content you want to use? And yes they are loadbalancing, but i guess it is made with DNS-loadbalancing.
  redundant-index 54
active
Yes it is Source-NAT. It is the address that the CSS will use to reach the added services.
    port 443
    protocol tcp
    redundant-index 41
Because they can! The address isn't used on the CSS yet.
service star-1-9443
  protocol tcp
  port 9443
  redundant-index 21
  keepalive type tcp
  active
Why not? If you think it is useful, you can change the tcp port of your keepalive.
  redundant-index 56
  active
It's the SNAT for the two services above (star-1-9443, star-2-9443)
circuit VLAN645
To tell the CSS that this vip should be redundant in VRRP.
