12-15-2014 07:32 AM
I am seeing the following on our ACE:
/Admin# sh resource usage
Allocation
Resource Current Peak Min Max Denied
Context: Admin
conc-connections 333 517 100 2000000 0
mgmt-connections 12 28 100 100000 0
proxy-connections 0 18 0 262143 0
xlates 0 0 0 65535 0
acc-connections 0 0 0 105 0
bandwidth 37863 62528533 2500000 187500000 4848517
throughput 36819 62500000 1250000 62500000 4848517
mgmt-traffic rate 1044 28533 1250000 125000000 0
connection rate 10 126 100 120000 0
ssl-connections rate 0 0 0 7500 0
mac-miss rate 0 4 0 2000 0
inspect-conn rate 0 0 0 40000 0
http-comp rate 0 0 0 262144000 0
acl-memory 90040 90040 0 69793680 0
sticky 160 191 81920 819200 0
regexp 795 795 0 1048576 0
syslog buffer 4194304 4194304 0 4194304 0
syslog rate 2 170 0 100000 0
The bandwidth and throughput denied is very high. The license installed currently is the default .5 Gbps
Resource allocation is set for 0% min and 100% max for bandwidth and throughput.
Admin# show license status
Licensed Feature Count
Compression Performance in Mbps 2000
Web Optimization Concurrent Conns. 105
SSL transactions per second 7500
Virtualized contexts 20
Module bandwidth in Gbps 0.5
Where can I find more information on what server farm and when this traffic is being denied? Is there any history or graphs that would show this to see if it is actually causing issues with server performance?
Thanks.
12-15-2014 10:13 AM
If you have only one context and you see denies, then it means that you are hitting the limit. Unfortunately, you cannot see if a traffic to specific serverfarm is very high or if it is having an impact on specific serverfarm. This output is context wide. Of course, there will be an impact to the whole context since traffic would be dropped. If the denied counter is continuously increasing, i would suggest contacting local account team to upgrade the license on this device. Are you using any SNMP polling or have ANM. There may be certain parameters which could help but again, if these counters are increasing frequently, it is best to upgrade the license or ensure that only traffic that needs LB is hitting the ACE.
Kanwal
Note: Please mark answers if they are helpful.
