Need to change the Certificate in ACE that is using for HTTPS Management access
ranjith.kanisan
Level 2
Level 2
Dear Team,
Currently we are getting certificate cannot be trusted error in web browser while we are accessing the ACE through https. So we need to installed the new https certificate for https management connection to ACE for removing this error. We do not want to use the self signed certificate for https access to ACEmanagement. We have done the below configuration but there no luck, still its showing the previous self signed certificate in browser.
parameter-map type ssl MNGMT_SSL
cipher RSA_WITH_AES_128_CBC_SHA priority 2
ssl-proxy service PSERVICE_SERVER
key ACEKEY.key
cert ACECERT.cert
ssl advanced-options MNGMT_SSL
Kindly suggest how we can installed the certificate on ACE for only https management access.
Thanks in advance.
Regrads,
Ranjith
Jorge Bejarano
Level 10
Level 10
Ranjith,
You may want to see the details and recommendation relatedo to this situation and this bug:
CSCte42757
Jorge
Jorge Bejarano
Level 10
Level 10
Ranjith,
CSCte42757
Jorge
