Network Accounting Problem
alexcheng
Community Member
I have a serious network accouting problem arisen from content engine:
Our routers are connected to internal backbone router with enabling Netflow to bill the usage (from domestic to backbone) of each users.
However, the CE will affect the network accounting seriously because it will replace the sender IP address with its own address before sending out to the link.
Would you give me some solution to remedy the problem?
Very Very Urgent!!
Thanks a lot..
Alex
ciscomoderator
Administrator
Administrator
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
