Primary and Standby CM question
TCAM
In general, Primary and Standby CM's database tables, configurations, group polices should be sync'd up and looked identical, right?  What else will be different and will require to import onto standby CM manually?  Things like: SSL certificate, Secure store encryption...etcs.
Thanks!
Joe
Felix Arrieta
Hello Joe,
I don't think you're leaving anything behind in regards how primary and standby CM  sync works, just follow the steps from the configuration guide and everything will be taken care,if there was any doubt just let us know what WAAS software version your running and the specific question. Critical files like Secure-store and SSL certificates will be automatically sync as well.
Still, in my experience I stronly suggest to make sure your devices time settings are right.
Time settings is very important for the sync to work fine, best way is to use an NTP.
Please find the attached link to configure NTP and timezone:
Configuration Guide:
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v417/configuration/guide/other.html#wp1042418
Command Reference:
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v417/command/reference/glob_cfg.html#wp1496245
Good Luck!
Felix Arrieta
Hello Joe,
Command Reference:
Good Luck!
Perfect.  Thanks for taking time to answer my question Felix!!!
